Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Vehicle-Specific B-Body Discussion > Chevy Caprice
Old 03-05-2010, 05:38 AM   #1 (permalink)
sunstateturk's Avatar
91 caprice blowing up mufflers
Remove this ad!
hi,
i've got a 91 caprice with a 5.0 and cat delete. first i shredded the original muffler (which had a crack or two) with a backfire then a brand new muffler with the loudest backfire i've ever heard. any suggestions? maybe a faulty muffler? it broke the seam on the muffler right where it latches from the straight pipe coming back. seems to only happen when it gets really hot which is inevitable here in Florida.
safe rides,
turk
sunstateturk is offline
Old 03-05-2010, 06:17 AM   #2 (permalink)
94ss68c10's Avatar
Send a message via MSN to 94ss68c10
first off why is the car backfiring? second where did you get the mufflers from ? are they new?
*1994 Impala SS- Lt1 of course, WX3, CAI, 7 inch touch screen, 2 12" kenwoods in the trunk, 96,000+or- mi
*2008 GMC Seirra- 5.3L V8, crew cab, dark maroon mettalic
*2008 G6- 2.4L, gas mileage car, 4 door
*1968 C-10- 96,000+or- mi on the body, tennessee truck, 86 305ci H.O. , 4-Barrel edelbrock, LT headers, 12-Bolt rear end with 3.73's ,posi, 3-speed muncie, hurst shifter, sunpro gauges, **(SOLD)**
*2006 Grand Prix GXP- 30k miles, 5.3ltr LS4, !resonator!, Cutout, stealth grey
94ss68c10 is offline
Old 03-05-2010, 01:28 PM   #3 (permalink)
the muffler was brand new... not sure why it's backfiring... something's interrupting the ignition i guess. backfired again today with the straight pipe, no muffler so i've got some kind of ignition problem i guess
Old 03-05-2010, 07:41 PM   #4 (permalink)
oldskoolcaprice's Avatar
Probably has to do with timing, or ignition, or combustion, or spark, or how about take it somewhere to have it checked before you do any unnesessary damage to your caprice. :confused:
1995 9C1 Caprice, 318,000 miles, 2" drop, wide whites, bilstiens, bmr front, rear, uppers & lowers, moog front-end rebuild, 2800 stall, 3.5 MAF, aftermarket dual 13" electric fans, and decent flat-black paint job!
oldskoolcaprice is offline
Old 03-06-2010, 04:54 AM   #5 (permalink)
waynes91's Avatar
remember to disconnect your ecm b4 u check the timing,
waynes91 is offline
Old 03-06-2010, 10:27 AM   #6 (permalink)
my 95 backfires because the throttle cable isnt always tight but i have never heard of blowing up a muffler???? i would think that my car would of done it already since i cut my mufflers and still have stock resonators which are going very soon!!!!:eek:
4 B BODIES
2 SOLD CAPRICES
Old 03-06-2010, 11:22 AM   #7 (permalink)
dintymoore's Avatar
Originally Posted by sunstateturk View Post
hi,
safe rides,
turk
Did you delete some sensors, i.e. the O2 sensors for example? If so the car may be running very rich and that could contribute to the backfiring. I'm all for removing all the emissions on these cars (and changing them to LPG) but the system they made is designed to work as a unit, and I wouldn't remove just part of it and expect the rest to work normally.
If you do remove part of it, I'd figure out the reststance values of the sensors that were there and put some resistors there to act like dummy sensors. That might work.
dintymoore is online now
Old 03-06-2010, 05:54 PM   #8 (permalink)
HERD546's Avatar
There is only 1 O2 sensor on a 91 & 92 caprice its on the drivers side. They are easy to change. The connector may be green with corrosion and that would cause the the computer to make the car run rich. Also hows the clutch fan is it working? That may cause the car to run hot also. There is also a coolant temperature sensor. You don't say how many miles are on the caprice, and if you have done a recent tune up. I would start with a cap, rotor plugs,and new thermostat. You may want to do a coolant flush also. As far as a muffler you may want to try a Glasspack, I have never blown one apart.
Good Luck
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
HERD CLUB President.
www.theherd.com
1996 DGGM IMPALA SS
1995 BLACK CAPRICE SS WAGON
HERD546 is offline
What mufflers ??? green demon Wagon Discussion 9 07-23-2010 07:41 AM
Caprice 96 Heater blowing warm, no HOT air LT1Finn Chevy Caprice 7 04-10-2010 10:32 AM
Magnaflow Mufflers for 8th Gen SS Manoogia86 Chevy Impala 8th Gen Discussion 14 01-31-2010 10:42 PM
2006 Impala SS Mufflers-Flowmaster CHRISS1928 Chevy Impala Discussion 8 08-27-2009 06:30 PM
what would win a modded 1995 impala ss w/mufflers,TB,MAF,chip&airintakeor a... lost7pennies777 Chevy Impala Discussion 2 05-18-2008 04:44 PM
