Oil change indicator light - Chevy Impala Forums
Old 03-01-2010, 10:36 AM   #1 (permalink)
griffenspade's Avatar
My oil change light came on. Its only been like 2300 miles since last change, should I change the oil now, or drive those 700 miles b4 i change it?
How does the car "know" when to change the oil anyways?
griffenspade is offline   Reply With Quote
Old 03-01-2010, 01:20 PM   #2 (permalink)
rkvette's Avatar
did you remember to reset your oil life system ?, when doing last oil change.?.. these are really good systems.. some guys i know saved oil sample, from oil change / sent away for analysis, were right on with the gm numbers.!!!.. rkvette
rkvette is offline   Reply With Quote
Old 03-01-2010, 03:37 PM   #3 (permalink)
COLD STEEL's Avatar
It would be beneficial to you to state the year and make of your car.
COLD STEEL is offline   Reply With Quote
Old 03-07-2010, 12:28 PM   #4 (permalink)
reply
1995 caprice(police) 5.7 v8
Old 03-08-2010, 04:22 PM   #5 (permalink)
kyles91caprice's Avatar
did you check and make sure the oil was at the right fluid level? and what type of oil are you using.. ?
kyles91caprice is offline   Reply With Quote
Old 03-12-2010, 12:48 PM   #6 (permalink)
EMPIRE CUSTOMS's Avatar
I have a 95 caprice classic as well and the "low oil level" light comes on every other time I start the car, but the oil level is fine and new
EMPIRE CUSTOMS is offline   Reply With Quote
Old 03-12-2010, 01:45 PM   #7 (permalink)
The oil life monitor does NOT in anyway monitor actual oil condition. It is completely dependent on you manually resetting it when the oil is changed and then it monitors driving conditions. It will come on sooner if it is cold started a lot, stop and go a lot etc.
Reset it by turning the key to on but not starting the car and flooring the gas pedal I believe 3 times.
Old 03-12-2010, 02:07 PM   #8 (permalink)
dwaynes correct push it to the floor 3 times wtih the key in on position but the car not on
4 B BODIES
2 SOLD CAPRICES
POPIMPIN CUSTOMS I.N.C is offline   Reply With Quote
change oil light Pablo Chang 6th Gen Engine Performance 4 02-06-2010 04:37 AM
Change engine oil light???? 2005impala Automotive Discussion 7 12-16-2008 08:58 PM
How to change a light bulb impala04ss Chevy Impala Discussion 8 11-08-2008 04:25 PM
How do you get the change oil light to go off? auntbea Automotive Discussion 2 09-07-2007 07:05 AM
take Change oil light off 2005 impala? SOCALi MAMi Audio, Video, and Electronics 2 08-31-2007 10:59 PM
