Would like to know when did gm introduced roller lifters in the Chevy caprice 305 /
5 liters ? I would like to know this cuz i currently own a 1988 caprice LS wit a 305 4 barrel wich is very reliable i know it has roller's in this one. Now im looking at a killer price for a 1986 caprice brougham 305 4 barrel wich has much less millage on then mine (78k)vs(235k) plus looks much better.
Im asking this cuz i recently find out that flat lifters causes more friction , wear much much faster thus affecting the whole reliability of the engine . So i wanna know if the 1986 5 liters came with the roller one's . Im i better just keeping the one i have right now ,are flat lifters that bad ? thanks for your input
Don't worry about the 'old' school lifters, cars ran fine for years with them.
#3 (permalink) | |
You can always save up and custom build an engine for this 86 car latter and drop it in when you think the time is right. Hang around here long enough and you might even consider up grading to a LT1 or even an LSx series engines. __________________ 1977 Impala Sedan, 5.0L, TH200, 3.25:1, 82K miles, 27 Lifetime Warranty Parts. Does not like Dodge Pickups rear bumpers! 1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 352K miles, 10 Lifetime Warranty Parts. |
#4 (permalink) |
i would stay with a roller motor,they just recently removed zinc and phosphorus from all gasoline motor oils.that will increase wear on flat lifters.the factory roller cams started in late 86-87 (centerbolt valve cover) on b and f body motors.the trucks should be all flat tappit but have roller provisions. mid to early 80's gm had serious problems with the cam lobes wearing flat. i have replaced a few recently.i know this is an old post .
Have you visited the Impala Forums Store today? Thousands of cars & parts for sale! Last edited by regal301l98; 08-12-2009 at 07:47 AM.. |
#5 (permalink) |
I never knew GM introduced roller lifters on Caprice 305's.
Am I missing something? I've been using SB GM V8's for 35 years and never had a roller lifter engine that I know of. Do my '92 305's have them?
#6 (permalink) |
b and f body "original" motors got them,starting with the centerbolt valvecover motors.yes you do........ or are supposed to.
#7 (permalink) |
my caprice has regular flat lifters and that has 226,000 miles on it, all original. They can't be that bad.
#8 (permalink) | |
My 92's have centerbolt valve covers so it would appear that mine have rollers... I haven't tried looking through the oil filler hole. It's hard for me to imagine it would make a big difference in my cars. I'm not sure I buy into it personally, but who knows maybe it's an improvement and saves engine wear. I am generally of the mind that the least amount of parts a machine has the more reliable it is.
Have you visited the Impala Forums Store today? Thousands of cars & parts for sale! Last edited by dintymoore; 08-18-2009 at 10:50 AM.. |
#9 (permalink) |
roller lifters not rockers,makes the motor more efficient,less resistance,frees up some power,and on high mileage motors it means your cam should still have lobes left on it unlike most of the 80's 305's.............
only downside is a aftermarket roller cam will run you about $300 there's nothing wrong with a flat hyd cam setup.just, the roller is better for street cars.
#10 (permalink) |
Seems like a good thing for engine wear.
Do roller lifters ever fail?
#11 (permalink) |
the hydraulic portion can go bad like any other lifter but the roller portion that rides the cam is not likely to fail,at least before the rest of the motor.it is great for helping the motor last,but that also has to do with good maintance and oil changes.
| When did GM introduced roller lifters in the Chevy caprice 305? | m_tony48 | Chevy Caprice | 1 | 09-12-2008 12:55 AM |
| Will flat lifters last much less longer than roller ones in a Chevrolet | m_tony48 | Chevy Caprice | 2 | 09-11-2008 09:22 PM |
| Hi i would like to know when did GM introduced the roller lifters in the Chevy | m_tony48 | Chevy Caprice | 0 | 09-11-2008 09:22 PM |
| can i use a bubble caprice digital dash in a 1990 box chevy caprice? | Jasmine R | Chevy Caprice | 1 | 05-16-2008 01:19 AM |
| 1996 Chevy Impala SS question about lifters? | IllMaxwell | Chevy Impala Discussion | 4 | 05-15-2008 08:17 AM |
