1991 caprice bad fuel system...I think?
I bought a 1991 caprice from my uncle, he said all it needed was a fuel pump and a steering column...I replaced both but was trying to find out if the pump is bad because the car will crank but will not start.
I got the pump on and my mechanic said the wiring was crossed up and when he fixed it he then said that I need a new ECU because the pump works ( I heard it for myself) but gas wont enter the TBI to let the engine turn over and run, is this true or could it be bad fuel injectors ?
Well...
Did you check the fuses? Did you make sure that the fuel pump is properly connected? Check those first. If they are ok, I'd suspect a clogged fuel filter. They are cheap, and even if it ran great, you should change it anyway, so go ahead. Visually inspect the fuel lines, tank to throttle body, making sure that none are pinched, or otherwise faulty. Disconnect the control wire to make the coil fire (the wire from the ignition control module on the distributor, that goes to the coil) since we will be handling raw fuel, we don't want a random spark. Safety first. Get a short piece of hose the right length, and disconnect the fuel in line on the throttle body, run the hose into a basin (gasoline resistant, an old glass mayonaise, or peanut butter jar works great) and have an assistant turn over the car. That'll let you know if the fuel is going to the tb. After that, repost and we'll trouble shoot some more.
__________________ I'm an awesome guy, just ask me, I'll tell you all about it. |
| why does my 1991 cAprice overheat when i hit 75+ mph? | victor_cadi95 | Chevy Caprice | 8 | 04-09-2009 07:24 AM |
| 1991 chevy caprice classic? | Steven R | Chevy Caprice | 0 | 08-19-2008 05:22 PM |
| 1991 chevrolet caprice running hot? | chico_atl404 | Chevy Caprice | 6 | 03-19-2008 11:28 AM |
| I have a 1991 Chevy Caprice? | vwindon | Chevy Caprice | 3 | 03-19-2008 10:57 AM |
| I have a 1991 Chevy Caprice? | vwindon | Chevy Caprice | 0 | 03-17-2008 02:51 PM |
