I have a 57 4 dr. with a 283 and a powerglide tranny.
It has been sitting for about 3 months because it was too hot outside to work on it. Now that the heat wave has broke, I went to push it into my garage, and it will not get out of Park.
We have tried rocking it back & forth while trying to shift, I have checked the linkage in the column and under the hood. I can't see under the car to check the rest of it.
Has this happened to anybody else? What did you do to fix it?
Definitely not the brakes. The shifter will not move out of gear (will move slightly). The car rocked back and forth several inches both directions, and I could hear a slight clicking noise as if it was only partially in the park position.
