electric fan conversion - Chevy Impala Forums
post #1 of (permalink) Old 03-16-2015, 08:59 AM Thread Starter
fixitman's Avatar
how hard would it be to convert my clutch fan over to an electric fan? i have the towing package , so i have one small electric fan already. the reason i am asking is because i found two cracks in the "clutch Fan and coolant pump bracket" and it seems to be a difficult part to find.
1987 Caddilac Brougham 5.0
1993 Buick Century Wagon 3.3
1994 Buick Roadmaster wagon 5.7
2009 Chevy Cobalt
fixitman is offline
post #2 of (permalink) Old 03-16-2015, 09:32 AM
Caprice Classic with Class
Old Bones's Avatar
Quoted: 43 Post(s)
On my 83 I removed the crank driven fan and put an electric in no problem , still kept the original shroud.
Quadrajet Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Two-way dash-cam. Crazy Canuck behind the Wheel.
Old Bones is offline
post #3 of (permalink) Old 03-16-2015, 09:58 AM Thread Starter
fixitman's Avatar
think i will need to add any relays or sensors since i already have an electric fan there?
your engine looks great by the way.....
2009 Chevy Cobalt
fixitman is offline
post #4 of (permalink) Old 03-17-2015, 07:13 AM
Old Bones's Avatar
Quoted: 43 Post(s)
Mine came with all the needed wiring etc. I would ask at wherever your going to buy it.
post #5 of (permalink) Old 03-17-2015, 02:25 PM
Quoted: 24 Post(s)
You would need some wiring but the full details elude me, been so long. A you pull it junkyard would be great so you could see the donor.
If you like it he mechanical I believe I have the parts you need to replace what is cracked.
I do like the electrics better though.
If interested in fixing the mechanical setup shoot me a PM I would not be looking to get rich. I would see value in making the parts go somewhere other than my shed.
Dwayne J is offline
The Following User Says Thank You to Dwayne J For This Useful Post:
fixitman (03-18-2015)
post #6 of (permalink) Old 05-22-2015, 07:23 PM Thread Starter
fixitman's Avatar
So I ordered a wire harness from innovative wire, got a fan and 3 3/8 x 16 x 4 bolts and converted over to electric fans. Looks stock! It all worked great until I made everything permanent. Now it idles high and the fans run constantly. Plus I broke a tranny line! I will attack those issues tomorrow. I am exhausted as I also replaced front and back shocks.
fixitman is offline
post #7 of (permalink) Old 05-23-2015, 04:45 AM
Quoted: 24 Post(s)
Check the coolant temp sensor on the water pump, that is the likely cause of the fans always on. If disconnected, dead or a wire broke the PCM thinks it is like -40degrees which can cause high idle, but also can't confirm engine temp so it runs the fans in case hot.
Dwayne J is offline
post #8 of (permalink) Old 05-23-2015, 02:44 PM Thread Starter
fixitman's Avatar
I have checked everything! The strange part is there is no error code.
fixitman is offline
post #9 of (permalink) Old 05-23-2015, 07:34 PM
Quoted: 24 Post(s)
How are you confirming no code?
Dwayne J is offline
post #10 of (permalink) Old 05-24-2015, 04:37 AM Thread Starter
fixitman's Avatar
No ses light and I checked the climate controls. I also replaced the CTS for shits and giggles and there is no change.
fixitman is offline
post #11 of (permalink) Old 05-24-2015, 04:40 AM
Quoted: 24 Post(s)
I remember the climate control can display rpm, can it display coolant temp? The dash gauge is a different unintegrated sensor all it does is drive the dash needle. More interested in what the PCM is seeing.
Dwayne J is offline
post #12 of (permalink) Old 05-24-2015, 05:14 AM Thread Starter
fixitman's Avatar
Could it be in learn mode?
fixitman is offline
post #13 of (permalink) Old 05-24-2015, 05:15 AM Thread Starter
fixitman's Avatar
Yes it does display coolant temp.
fixitman is offline
post #14 of (permalink) Old 05-24-2015, 07:21 AM Thread Starter
fixitman's Avatar
I fixed it! I found a loose wire on the ecm. I knew it had to be something stupid like that! She runs like a different car now, new shocks, CTS sensor, electric fan conversion and cold air intake. Now I just have to tackle the rear brakes and an exhaust leak.both of which are ugly. Thanks for your help.
fixitman is offline
post #15 of (permalink) Old 05-25-2015, 07:09 AM
Quoted: 24 Post(s)
Upgraded wagon tailpipes are going to tough but if not aiming too high hp the stockers could serve fine, sedan parts are the same mufflers forward.
Dwayne J is offline
Electric Fan problems? tjss75 Chevy Impala 8th Gen Discussion 5 01-07-2014 10:45 AM
Electric fan conversion thacarter546 Automotive Discussion 3 07-22-2011 09:20 PM
Electric Fan Problem 1995CapriceClassic Chevy Caprice 2 07-15-2011 03:16 PM
Electric Fan Conversion 95 capss PCM and Technical Tuning 6 11-05-2010 10:54 AM
fan swap to electric Bizkitss81 Chevy Caprice 3 03-16-2010 08:11 PM
