1995 Roadmaster LT1 Rear end swap/ Posi Installation - Chevy Impala Forums
post #1 of (permalink) Old 03-30-2011, 04:29 AM Thread Starter
Jarin_Chandler's Avatar
Question 1995 Roadmaster LT1 Rear end swap/ Posi Installation
I LOVE my '95 Roadmaster...except for one little thing. She will only lite up the rear passenger tire! This is fun to do but I am getting sick of having to rotate the tires all the rime. I am happy with the gear ratios, I do a lot of highway driving and I don't want to kill my amazing 25 MPG. (I will never admit this but the acceleration between 55 and 115 in unbelievable. Stupid governor ) However I definitely want to install a posi so the tires will wear more evenly and so she will stop pulling (maybe rolling would be a better description) to the left when I go hot off the line. As I gradually continue to upgrade the LT1, this is becoming more and more of a problem. Help! What am I looking for? Is there something I can find at the junkyard or do I have to go new? You guys are awesome. GM is awesome. Awesomeness all around.
Jarin_Chandler is offline
post #2 of (permalink) Old 03-30-2011, 06:08 AM
MrBuick (Magnum)'s Avatar
2.56's are good for one thing, and one thing only. Creating a smoke show. Once you get a tire going with those gears, it is extremely hard to get it to stop. Well, there are a few other quality's. Like towing on the highway in 3rd gear. RPM's are still not that high, and saves the tranny. Or if your 4L60E becomes a powerglide, you don't have to get it fixed right away. I put 3,000 miles on my 95 Red Roadmaster beater with no 3rd or 4th gear. I still drove it on the highway at 65mph. At the dragstrip, I was crossing the 1/4 mile trap in 2nd gear!
Really, 2.93's or 3.08's still offer very good gas mileage, with an improvement in off the line performance. 2.56's used a series II carrier, than only supported the 2.56, 2.41, 2.14 and "higher" gear ratios. 2.56 was the only from that used in the 91-96 Roadmaster. The series III carriers covered everything else such as 2.73, 2.93, 3.08, 3.23, 3.42, 3.73, 4.10, 4.56, 4.88, and even "lower". You can use a series II carrier with series III gear sets, but the ring gear requires a spacer. Series III carriers don't work with series II gear sets. The pinion head is way to big.
The only car to have a positraction with 2.56 gears, was the 94-96 Roadmaster SEDAN. It was optional, and on about 1/4 of the 94-96 Roadmaster sedans. I have only come across a handful of them, while looking at Roadmasters FS or in the junkyards. Not sure where they all ended up. You can swap the carrier if you find a good used one. Just need to re shim it side to side to get the pattern / backlash right for the gears. Or, and you are more likely to find a posi still working with an entire axle swap with one from a 91-96 Caprice sedan/ Roadmaster sedan.
The sedans used a housing in two widths. The 93-96 Civi Caprice / Impala SS used the wide housing. The Roadmaster sedans, 91-92 Caprice sedans, or 91-96 Caprice 9C1's used the skinnier housing. The wider housing will work, but it will push the tires closer to the fender, which will make it harder to get the tires out, and also will take away from the width of of tires you can use on the stock rims, or rims with a similar backspacing. The stock positraction was not known as being extremely long lasting. Some are junk by 100k and acting like an open diff, while others are still strong at 200k. I have seen them every where in between. I have had ones that were garbage around 100k, and others that would still light both rear tires up at 220k. The one in my 95 RMS "Jesus", has 86k on it, and is weak sometimes. One of the Caprices I had with 150k, that posi was still extremely strong. they can be hit or miss. Aftermarket ones can be had for a series III gear set, and run about $300-$500 depending on what you go with. I have a clutch based Eaton in 95 RMS "Buffmans car", and my 96 Caprice 9C1. If I did it again, I think I would go with a detriot locker, and never have to worry about replacing it again. But, they are expensive.
2.93's/3.08's are still really great on gas, and much easier to find with a positraction that is still working. My 94 Fleetwood had 2.93's(same engine/tranny) and got 24mpg from FL to MI. knowing my dad, he drove 65mph-75mph depending on the speed limit. 2.93 posi was the setup used on the 94-96 Roadmaster/Caprice sedan with the towing package. 3.08 (posi optional) was used on the 94-96 LT1 Caprice 9C1. The L99 Caprice 9C1's were 3.23(posi optional). Some 91-93 Caprice 9C1's were 3.42(posi optional). 92/93 Roadmaster sedans with the towing package were 3.08(posi optional). There were other 91-93 Caprices with 3.08's. But, the civi caprice sedans were the wider housing that is worth noting. The Impala SS was 3.08 posi on the wide housing. All of the 94-96 Impala SS/ 9C1's had a rear disc setup. In stock form, it was crap. But a cheap and easy mod makes them more effective.
The Caprice sedan also used a 7.5" axle behind the L99(4.3) / LO3(5.0/305) caprice sedans that were not 9C1's. None of them are positraction, but you don't want one of them even if it is free. Well, unless you use it for a paper weight.
I pulled a 93 Caprice civi axle, that is a wide housing 3.08 with a surprisingly strong posi. It's going under my winter beater 95 Red RMS, so tire width is not an issue. Plus, I want to get away for the horrendous 2.56's on top of adding a posi for snow. I also pulled a 93 9C1 axle that is 3.42 posi for my 95 RMS "Jesus". The 94-96 Fleetwood had 3.42's in the towing package, and they were still rated at 22-24mpg(forget exactly) highway, IIRC. I have also pulled a few 3.08 posi axles from 94-96 Caprice 9C1's. I go get mine on a half price day at the U-pull it yards. But even at full price, they are cheap.
I can normally pull one in a yard, by myself, in around 2 hours. The hardest part is cutting the parking brake, and then attempting to lift it in the wheel barrel. I'm not very big, and lifting HALF of a loaded 8.5" axle is hard for me. There was a write up on auto blogs, on doing an axle swap on a 94-96 Roadmaster sedan.
Don't bother with wagon axles. They are even wider, and have hte LCA mounts spread farther apart. But a carrier from one will work.
MrBuick (Magnum) is offline
post #3 of (permalink) Old 03-30-2011, 11:08 PM Thread Starter
Fantastic Info
Thank you sir that is some fantastic info! My brain is smoking like my rear passenger tire. Next paycheck I will hit the junkyards and be back with some pics, and hopefully some new parts!
post #4 of (permalink) Old 03-31-2011, 03:06 PM
thacarter546's Avatar
So just a question for you man. I have a 92 Caprice Classic LTZ Towing package.
I have the original window sticker and the sticker in the trunk that say I have a 3.23 with the limited slip.
Surely the 3.23 Posi was fairly common in the towing packs as well.
thacarter546 is offline
post #5 of (permalink) Old 04-01-2011, 01:47 AM
I don't know all the details on the 91-93's, especially the Caprice. There were quite a few of 91-93(94's too, but I have not confirmed 95/96 Civi cars that seemed to sneak 3.23's in. I still have not figured out what rules they followed. I wouldn't say it is fairly common, as 3.23's seemed to pop up in odd spots. Like my friends 94 Caprice Civi, that is an L99 car. No towing package, or it would have an LT1. It has the HD suspension, and a posi. It's just odd that you could order 3.23's. Maybe they were on the options list in 91-93 that wasn't a set combo. I don't know the answer to that.
I just checked the VIN of a Random 92 Caprice sedan, and it was an LO3 car(305), V92(towing package), GU4(3.08), G80(posi), FE2(ride handling suspension). Out of over 100,000 cars, only 1,800 had the FE2 suspension code. That is a very small percentage. 11,000 had 3.08's, 20,000 had positraction. The most stagging piece, is 2400 with the V92 towing package.
That assumes all of this info is accurate. The decoder is becoming less and less useful, unless you pay for it. Unless I have the VIN of a 92 Caprice with 3.23's, I can;t say how many came with them.
Here is the VIN I ran off a car on EBAY.
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, and Mazda Trucks VIN Decoder
post #6 of (permalink) Old 04-01-2011, 02:21 AM Thread Starter
MrBuick, you are hardcore!
post #7 of (permalink) Old 04-01-2011, 06:31 AM
Quoted: 18 Post(s)
On a trip with my 94 wagon I ended up in the Appalachians with over 500lbs of people and easily 700lbs worth of cargo, was September so it was warm. Thing came with 2.56s. I used drive instead of overdrive in the hills to keep it locked up rather than unlocking the converter and downshifting constantly. I got 24-25mpg like that.
3.42 is a great gear for even a highway car, we have overdrive and lockup keeping rpms down.
Dwayne J is offline
post #8 of (permalink) Old 04-01-2011, 05:16 PM
IDK I have the window sticker to mine, I know te previous owners changed a few things. Like I know 96 impala wheels didnt come on it lol
post #9 of (permalink) Old 04-01-2011, 06:11 PM
H3AvY Ch3vY bOy's Avatar
x2 lol ive been wanting to swap to posi since i sold my 91 that had it,
thx 4 all the info!
H3AvY Ch3vY bOy is offline
post #10 of (permalink) Old 05-12-2011, 11:06 AM
longfingaz's Avatar
What is my best option for getting my open rear in a 96 Buick Roadmaster Wagon converted to a LSD / Posi rear from a 94 - 96 roadmaster sedan?
I have the full rear from the sedan...
Should I ..
1. Swap the entire rear out of the wagon for the entire rear from the sedan? are they the same axles and length etc.. or will i be changing from the stock specs?
2. Swap the "pumpkin"? ( I have never done this, only full rear swaps)
3. Swap the "Carriers" ? ( I have never done this either, but I believe it is the simplest way?)
Any help would be greatly appreciated. My goal to simply go from stock open ended to stock LSD /Posi with as little work required. This is my daily driver and I just want it to be better in the snow next winter.
Thanks!!
longfingaz is offline
post #11 of (permalink) Old 05-20-2011, 12:32 AM
The carrier is the pumpkin.
If you have a 2.56 geared wagon, you must use a carrier from a 2.56 axle. Plain and simple. Other wise, the carrier will swap over, and it just needs to be shimmed, and measured.
The sedan, and wagon housings are not the same width. There will be issues, and I'm pretty sure I already addressed this. But maybe that was another thread in this section.
Short answer, the sedan housing can be forced to fit. But it's not exactly something I can agree with doing. Now, if I ever get the chance to see it done, and the effects, then who knows, I might change my opinion. As much as I strive to be a perfectionist, I'm still a backyard mechanic with redneck fix tendencies. long answer entails details about width, and angle issues.
LinkBack to this Thread: http://www.impalaforums.com/buick-roadmaster/279375-1995-roadmaster-lt1-rear-end-swap-posi-installation.html
95 Buick Roadmaster rearend and engine This thread Refback 03-21-2013 06:33 PM
looking to swap out stock 95 caprice rear for a posi, need info 95caprice_doublebubble Chevy Caprice 6 02-11-2014 08:50 AM
1995 caprice wagon rear end swap gpashen Wagon Discussion 12 11-18-2010 11:15 AM
Posi Rear plz help Jasebaby87 Chevy Caprice 4 05-13-2010 12:39 AM
Posi/Rear end questions TX95SS 6th Gen Drivetrain 4 04-04-2010 03:18 PM
Posi rear end costs thaboss318 6th Gen Drivetrain 3 11-17-2009 10:34 PM
