1994 Buick Road Master will not start. Turn's over but won't start? - Chevy Impala Forums
post #1 of (permalink) Old 02-26-2008, 08:37 PM
Rambro2005
Rambro2005's Avatar
Quoted: Post(s)
I drove my ar yesterday and it just cut off. I change the fuel filter, charge the battery but it dies quickly after that. I'm about to have it towed to a service dealer. Any help will be greatly appreciated.
post #2 of (permalink) Old 02-26-2008, 08:37 PM
divesharksnemo
divesharksnemo's Avatar
Quoted: Post(s)
pull aplug wire off, have somebody try to start it. if no spark, need to change hei mod under the dist cap.if you have fuel and fire, i dont know???
post #3 of (permalink) Old 02-26-2008, 08:38 PM
texczech1951
texczech1951's Avatar
Quoted: Post(s)
check to see if the in tank fuel pump is coming on- if you turn the key on but don't start it, the in tank pump will run for 2 seconds & cut off. Try this and try to listen for the fuel pump hum in the tank( this may require a helper) If you don't think lit is coming on, try hitting the bottom of the tank while someone cranks-sometimes this will wake up a tired pump & get it started- then you know the in tank pump is bad!- It may take 20 -30 seconds of cranking & hitting the bottom of the tank for this to work.
post #4 of (permalink) Old 02-26-2008, 08:38 PM
Cal
Cal's Avatar
Quoted: Post(s)
First things first. Determine if it's a firing or ignition problem.
Check to be sure it has proper fuel fuel pressure. If not, the fuel pump is probably bad. But check the F.P. fuse also. Pull a spark plug wire and check to see if you have ignition fire. If not , the ignition module may be fried or the PCM has given up on you. Check the interrupter coil near the harmonic balancer for having oil on it. That could be the problem. It controls the ignition firing sequence. You can check it with a DVOM, using the ohms setting.
Hope this helps.
Master tech 40 yrs.
i have a 96 buick road master and my left blinker bulb is on but not blinking? CARLAS H Buick Roadmaster 6 09-05-2008 04:17 PM
I have a 1994 Z28 LT1 camaro. It will not start and there is smoke coming... Z28EP Automotive Discussion 1 06-21-2008 03:49 AM
1994 buick roadmaster won't start? boredguywisconsin Buick Roadmaster 3 05-07-2008 10:36 AM
53 buick road master? TUFF AS IT GETS Buick Roadmaster 1 02-26-2008 08:38 PM
Why will my 1994 Chevrolet Caprice Classic not start? shannon Chevy Caprice 1 02-21-2008 05:00 AM
