OBD trigger codes - Chevy Impala Forums
Go Back   Chevy Impala Forums > General Discussion > Automotive Discussion
Old 07-31-2011, 07:51 PM   #1 (permalink)
rosa6329's Avatar
Exclamation OBD trigger codes
So I just had one my friends hook up my car to an OBD reader. Here are the following codes that my car has had.
B-comes from the BCM
C- comes from ABS/TIM/TCS
P-comes from PCM
B1440 - Power Mode Master Input Circuits Mismatch
B2602- Daytime Running Lamp Control 1 Circuit Low
B2650 - Left Hand Daytime Running Lights Filament Open
B2958 - Security System Sensor Data Circuit High
B2968 - couldnt find any information for this code
B3128 - Left Front Door Only Unlock Circuit High
C1234 - Left Rear Wheel Speed Sensor Circuit Open Or Shorted
C1245 - Low Tire Pressure Detected
P1811 - Maximum Adapt And Long Shift
so maybe I do need a new bcm?
2004 Impala SS 3.8 Super Charged
Throttle Body Space
3.4 Pulley
K&N Cold Air Intake System
rosa6329 is offline   Reply With Quote Quick reply to this message
RPO Codes... jssmith76 Chevy Impala 8th Gen Discussion 7 05-03-2011 11:42 AM
GM RPO Codes/package #'s dustin3207 Chevy Caprice 1 03-04-2011 07:31 PM
CEL codes craige211 Chevy Impala 6th Gen Discussion 3 08-22-2010 08:48 PM
Lean codes help 96impala 6th Gen Engine Performance 0 06-29-2010 11:38 AM
Help with Codes pulled on '04 Chris91LX Chevy Impala 7th Gen Discussion 23 02-26-2010 07:55 AM
