Chevy Impala SS Forums
Old 06-24-2009, 10:13 AM   #1 (permalink)
350 intake torque specs?
Does anyone know the torque specs for the intake bolts off hand? I am at work and don't have my manual with me.
Dual Flowmaster exuast with hi-flow cat, not on yet...
2.41 Open carrier performance!
(95 9C1 3.08 waiting to be installed!)
16x8 American Racing Baja's with 225/60/16 Bridgestone Potenza RE910's
(soon to be Pirelli P5's)
Panasonic CD player with all Polk speakers 2-4x6, 2-6x9, 2-12" on alpine 4 channel (till I get my other amp fixed).
Sponsored links
Old 06-28-2009, 10:22 PM   #2 (permalink)
Gregg-O's Avatar
For some reason I have 35ft lbs in my head....Found this; Sounds about right to me
"According to my Chevrolet Factory Performance Guide, the spec's call for 30 ft. lbs. of torque working from the center bolts in a criss-cross fashion to the end bolts. Use thread sealer on clean bolts, and a drop or two of engine oil where the head of the bolts contact the intake. The intake gaskets will settle, and after sitting over night, go over them again with the torque wrench. Many mechanics use the three pound added torque to insure a good seal, but I have had engines that had to be gone over several times before they finally stopped leaking. If after you torque them they leak, then go 1/8 of a turn more, and this should fix it"
Gregg-O is offline
Old 06-29-2009, 12:45 PM   #3 (permalink)
Thanks. Seems like that is a more likely cause to the problems I have been having with oil consumption, since it's on mainly one cylinder, a little on the one next to it, and I pulled the oil pan not that long ago and there were no piston ring pieces in it...
vB code is On
Plug wire resistance specs AKvsAR 7th Gen Engine Performance 2 01-28-2009 10:42 AM
Tech specs on non-altered 96 SS 96SSAgain Chevy Impala 6th Gen Discussion 2 12-30-2008 07:33 PM
05 impala factory amp specs MotoCpl Chevy Impala Discussion 0 10-10-2008 05:26 PM
What can I do to get more hp and torque out of my lt1 z28 for little money? Horton Automotive Discussion 0 06-21-2008 07:05 AM
short ram intake vs stock intake? clay10_91 Automotive Discussion 2 09-06-2007 04:04 AM
Sitemap Index - Archive
