| Autocare and Maintenance Auto detailing, care, and maintenance. |
LinkBack (1) | Thread Tools | Display Modes |
#1 (permalink)
Traction control service light
I have a service traction light, Is it a wheel speed sensor wire or something else. Can anyone help, Thanks 2004 Impala LS
Looking for Impala parts? Try The Chevy Impala SS Forums - Impala Store! Last edited by cfjames11 : 03-31-2008 at 05:11 PM. Reason: No Model |
i had the same problem 2 weeks ago so i check the wiring in all tires and i found 1 cut wire so i fixed miself and the traction light go off
#3 (permalink) |
wheel speed sensor is built into the wheel hub ($100-400 depending on source/mfg), and fairly easy to swap out.
tools needed: 34,18, 15, 13mm sockets big hammer jack & stands 3/8 socket, universal joint, possibly extensions possibly a pickle fork http://www.paulstravelpictures.com/G...ent/index.html
I am Wanderson's bitch . ![]() See the NEW project: http://www.fullthrottlev6.com/forums...ad.php?t=59648 |
#4 (permalink) |
Traction control light
I went through this problem with my 2001 Impala LS at around 100K miles. Replace the hub bearings with integrated sensors because fault codes indicated this to be the problem, and there was a humming sound from the front (later learned that Potenza G009 tires at wear limit are LOUD, and sound like shot bearings!). Light started coming back after replacing the bearings. Blogs I checked pointing to wiring harness being the issue so wiring harness to each wheel was replaced, and BINGO - problem gone. Probably never needed the wheel bearings - was the wires all along. I would start with the wires as this seems to be a recurring problem found on the blogs, such as automotiveforums.com (Impala section of site). Don't listen to dealer tell you the entire front wiring needs to be replaced (around $1000!). There is a harness kit for about 100 bucks.
LinkBack to this Thread: http://www.impalaforums.com/autocare-maintenance/19723-traction-control-service-light.html
| Impala - TRACTION ACTIVE warning light - Topic : | This thread | Refback | 03-11-2009 09:36 PM | |
| Service Traction Control problem | AKvsAR | Chevy Impala 7th Gen Discussion | 23 | 07-04-2009 04:29 PM |
| Traction Control light | bigcat24 | Chevy Impala Discussion | 11 | 03-09-2009 11:35 AM |
| Service Traction Control System | indyimpalass | 7th Gen Drivetrain | 9 | 02-15-2009 08:09 AM |
| Service Traction System **Update** | indyimpalass | Autocare and Maintenance | 2 | 01-23-2009 06:26 PM |
| 2002 Chevy Impala Service Traction System Light comes on with ABS light;... | preciousmoments | Mechanical and Electrical Problems | 2 | 09-06-2007 03:01 AM |
