2005 Impala Knocking Noise
I have a 2005 Impala and when I'm driving and turn left or right I hear a knocking noise. When I'm sitting still and turn the wheel there is no knock at all. I'm very confused as to what it can be. Also, when I turn the wheel it makes a funny noise, sort of sounds like a zipper. Any and all input is greatly appreciated.
| Sponsored links | |
Is the "knocking" coming from the left side or right? I would check the outer CV joints. If you find a missing, cracked or torn CV boot then you have found the bad joint. The joint will need to be replaced.
The "zipper" noise may be from the felt (or simular) material used in the steering column (it is supposed to be some sort of bushing), it may be dry and making the sound. Chevys are known for this. If so you may want to live with it until you really need to take the column apart.
1977 Impala Sedan, 5.0L, TH200R, 3.25:1, 74K miles, 26 Lifetime Warranty Parts. 1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 335K miles, 6 Lifetime Warranty Parts. |
#4 (permalink) |
I can't pinpoint the knocking noise, I just hear it and feel it in the steering wheel whenever I turn. Also to Detroit, it does kind of creek, mostly when I'm waiting to turn and pull off. Can you please elaborate a little more?
#5 (permalink) |
Bulletin No.: 01-02-32-001J
Date: June 08, 2007 TECHNICAL Subject: Clunk Felt/Noise Heard From Steering Column, Steering Gear and/or Front Of Vehicle During Turning Maneuver and/or Steering Wheel Rotation (Lubricate or Replace Intermediate Shaft As Appropriate) Models: 2001-2004 Buick Regal 2005-2007 Buick Allure (Canada Only), LaCrosse 1997-2005 Chevrolet Cavalier 2000-2007 Chevrolet Impala, Monte Carlo 1998-2002 Oldsmobile Intrigue 1997-2005 Pontiac Sunfire 2004-2007 Pontiac Grand Prix Condition Some customers may comment on a clunk type noise coming from the front of the vehicle while driving during a turning maneuver. This condition may also be felt through the steering wheel when the vehicle is stationary and the wheel is rotated from steering stop to steering stop. Some vehicles may only exhibit the noise once for every 360°of wheel rotation. On all other vehicles, this clunk noise will be noticed during low speed acceleration or deceleration, typically in light turns of the steering wheel. Cause This condition may be caused by inadequate lubrication of the steering intermediate shaft which results in a slip stick condition possibly resulting in the clunk noise. Correction Due to the design of the new I-shaft, it is not possible to lubricate/grease the I-shaft. Replace the existing steering intermediate shaft using the service procedure found in Service Information. The remaining vehicles listed below will still need to have the current I-shafts re-lubricated. New I-shafts will be released later in 2007 for some of the remaining vehicles. Shaft assembly - Steering gear Part number 25829294 00-05 Impala |
#8 (permalink) | |
similar problem
| Sponsored links | |
| strange noise.. | sportsfreak1124 | Chevy Impala 7th Gen Discussion | 0 | 10-16-2008 05:48 PM |
| 93 Caddy Fleetwood Brougham 5.7 TBI RWD knocking on startup? | Ashley H | Cadillac Fleetwood | 1 | 07-11-2008 06:26 AM |
| Transmission makes knocking noise when it shifts back to first in my 93 Firebird | formula93_350 | General Automotive Discussion | 0 | 06-21-2008 05:57 AM |
| Knocking noise when I turn my 92' Buick Roadmaster on? | rsgree | Buick Roadmaster | 0 | 02-20-2008 12:53 PM |
| I hear a knocking sound when i turn left on my 2007 impala? | oyousefian | Mechanical and Electrical Problems | 0 | 09-14-2007 08:04 PM |
