I have no idea wat kind of oil or transmission oil it uses. If any one knows let me know. also wat are some good sites to learn more about my car, its parts, and how to maintain it. And wat gas should i use reg. unleaded or ultimate? |
| Sponsored links | |
The transmission definitely uses Dexron, so any of the dexron's will work, dexron 3 up to 6 is fine. As for oil I suggest 10w30 or 20w50 in the summer. To quiet the valves and lifters. As for gas, you should be able to use regular, but if it starts to ping a bit, I would switch to at least midgrade.
#3 (permalink) |
On the transmission oil use Dexron III, that is what came in the Turbo Hydramatic series of transmissions for this year car.
Oil 10W-30 is the recommended all year round. As stated above 20W-50 is fine for the summer. On the fuel use only regular unleaded. If you start to get the gas ping first run a good fuel cleaner, second check the base distributer timing, which should be 8 degrees BTDC. Due to timing chain wear this may have to be adjusted. Also make sure the vacuum lines & operated devices are in good condition. A good thing to have around is a Chiltons Repair Manual #28420, I like it over the Haynes #24045. The Chiltons has vacuum diagrams which the Haynes does not. The Chiltons also covers removal of many dash componets such as the gage clustor. I have both manuals. These are available from your local auto parts store.
1977 Impala Sedan, 5.0L, TH200R, 3.25:1, 74K miles, 26 Lifetime Warranty Parts. 1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 335K miles, 6 Lifetime Warranty Parts. Last edited by 77Impala : 09-21-2008 at 06:07 PM. |
| Sponsored links | |
| JUST BOUGHT A 2007 Chevy Impala SS | Jonnyray1 | 8th Gen Engine Performance | 2 | 10-07-2008 05:12 AM |
| i just bought a 64 chevy biscayne...what type of engine will it fit?????????????????? | Alfonso M | Chevy Biscayne | 1 | 05-24-2008 11:21 AM |
| just bought a 2000 chevy impala and theres a switch....? | c.r. | Chevy Impala Discussion | 2 | 05-08-2008 09:18 PM |
| i have a 1987 chevy caprice that i just bought and was wondering...? | Jonathan | Chevy Caprice | 4 | 02-20-2008 05:35 PM |
