96 Impala 4L60E grinding noise - Chevy Impala Forums
post #1 of (permalink) Old 05-14-2008, 05:10 PM Thread Starter
aleman33's Avatar
4L60E- When on drive and suddenly step on the gas I hear a grinding noise coming from my transmission. Anyone have any idea what this could be? thank you...
aleman33 is offline
post #2 of (permalink) Old 05-15-2008, 09:41 AM
pauly383's Avatar
Originally Posted by shawndejesus9@aol.com View Post
when is the last time you changed your fluid, i has 22s on my 9c1 when i was on the freeway i steped on the gas, i heard my tranny grind and then i smelled the fluid my friend had the same problem he has 24s if your tranny has high miles like mines the wheels wear it out quicker i asked around other people with big rims alot of them had put shift kits or rebuild their tranny with high performance parts,hope it helps out
The real solution to larger wheels and tires is to regear the rearend . Just like four wheelers do to return the vehicle to the same rpm it used to cruise at when stock .
As for the 4l60e , I have one in a pickup that makes that noise in 3rd , and in my case at 204,000 miles its just worn out now .
70 Malibu , 75 K5 , 83 K5 , 93 K2500 , 99 Suburban , 2003 Impala . four are mine , two are hers , two haven't seen daylight in several years :tongue:
pauly383 is offline
post #3 of (permalink) Old 05-15-2008, 01:57 PM
Dustman's Avatar
if its grinding something internal is going. And a fluid flush wont help.
Take a look at out transmissions and lmk if we can help
www.cpt4l60e.com
Shane Cobb
Hangar 18 Perf Mighty Mouse 350 LT1
11.7 @ 115
Member of the E Pugilize jimbeau crew
::LOCKUP DUSTMAN!!::
Dustman is offline
post #4 of (permalink) Old 06-05-2008, 01:13 PM
shawndejesus9@aol.com's Avatar
i have a 9c1 state trooper car when you take it out of park it goes into first gear,but when you come into a full stop it goes into 3rd gear and change the speed sensors and know it makes a wierd sound from the tranny as you go faster it gets louder i matched both sensors up they are the same size
shawndejesus9@aol.com is offline
96 impala grinding vibrating noise around torque converter aleman33 Chevy Caprice 5 04-20-2009 05:17 PM
weight of 93 caprice wagon 5.7 -4l60e car? michael_stewart32 Wagon Discussion 3 07-02-2008 01:35 AM
what other transmission will fit in my 1996 buick roadmaster besides the 4l60e? george h Buick Roadmaster 4 05-08-2008 06:56 AM
03' Impala - grinding sound from front right wheel FormatFusion Mechanical and Electrical Problems 0 04-17-2008 03:15 PM
Can i put a 2006 Vortec 5.3 along with a 4L60E auto trans. into a 1977-79... chevytruck1500 Chevy Impala Discussion 1 11-02-2007 06:22 PM
