| Autocare and Maintenance Auto detailing, care, and maintenance. |
69 impala-overheating and lots of play in steering wheel
Hey everyone, I just purchased a 69 impala for a new project car. However, this is my first project car. The impala will climb up in temp when just driving across town. A mechanic said to take out the thermostat and that should keep the car running at an good operating temp. also, the steering is really loose, is there a way to tighten it w/o going to a shop? as far, as the excessive heat climb, are there other parts i should check along with removing the thermostat?
Thanks! B |
| Sponsored Links | |||
Advertisement | |||
Back in Black
Check fan clutch if you have regular fan, with car off see if fan turns with a little push, should have a good amount of resistance. Also after car has been running or driven across town check radiator, again with car off place hand on radiator if you have any cold spots you might have a blockage. Also test to see if you have proper water antifreeze mix.
Not sure where you live but I would not leave thermostat out of car Not sure about steering but check tie rods, ball joints and other steering linkage. 69's are very nice cars have fun with it. |
#3 (permalink) |
& Barricade
![]() Join Date: Jan 2011
You can test to see if the thermostat is bad by running without it for a bit; But, Thermostats are pretty cheap. Just buy a new one. It wont hurt anything to have replaced it, and it might fix the issue.
__________________ Jackass of all Trades Tri-9 Defined: 1994, 1995 or 1996 B-Body. ![]() 1994 9c1- 300,000 miles and counting. |
#7 (permalink) |
check the radiator to see if there a lot of scale build up on the tubes,swap out the t stat,if u have a clutch fan, bring motor up to operating temp (ur case be careful lol) then turn motor off, the fan should only turn about 2 times and stop, if it keeps turning more then its shot. check all the front end components,check the rag joint (the coupling between the steering box and steering column ) if the str bx is bad get a good rebuilt one,theres good ones in the hod rod magazines, or send urs out to them for a rebuild if u want to keep it all original. damn 69's are sweet wish i had one..
| Sponsored Links | |
Advertisement | |
| Stock Steering wheel to a 1965 steering wheel | Joeysimpala | Chevy Impala 6th Gen Discussion | 4 | 01-21-2013 12:42 AM |
| Steering wheel dimension for steering wheel cover | mmanter | Chevy Impala 7th Gen Discussion | 3 | 08-21-2012 05:13 AM |
| Chevrolet : Impala LT LT Ethanol - FFV 3.5L Front Wheel Drive Power Steering 4-Wheel | RSS Bot | eBay Cars For Sale: Impala | 0 | 11-10-2011 10:15 AM |
| Play in rear wheel | dupras2453 | Chevy Impala 7th Gen Discussion | 3 | 03-09-2011 10:39 AM |
| Steering wheel play | IonicRipper | Mechanical and Electrical Problems | 15 | 08-01-2010 11:33 AM |
