Throttle Position Sensor gone bad? - Chevy Impala Forums
post #1 of (permalink) Old 09-04-2011, 09:34 PM Thread Starter
Nitrocide595's Avatar
Question Throttle Position Sensor gone bad?
I thought it was my transmission for a while, but now I'm having second thoughts-
My 03 has a few problems- first gear winding up, the shift is late and the motor revs before shifting- not OVER-REVVING, but to the point where I hit a speed (I forget now) and it'll rev a few hundred more RPM without picking up speed before it shifts.
When cruising at about 40, I floor it and it doesn't shift back into first, instead it gets really doggy and lumbers up to 55 or so at a steady-slow pace.
Dad's got the scanner from work so I'm gonna plug it in tomorrow hopefully and just see if it comes back with either a code or another problem.
I'm kinda hoping it's not the transmission because a TPS is about $35 at Advance Auto Parts, and a new Trannie (when it finally blows up on me) is upwards of $1000...
Thoughts? Suggestions?
-I'm done here. Bye guys.
Nitrocide595 is offline
post #2 of (permalink) Old 09-04-2011, 10:08 PM
The Unscrupulous Lt. Colonel
Crime Scene's Avatar
Sounds like just that. TPS. Same thing happened to me, my first thought was fuck. $700 for a rebuild, a Torque converter, rear main seal, flywheel, and a side of transmission fluid for breakfast.
But i just happened to be close to an auto parts store at the time, and had the car scanned. Came up TPS low voltage. $20 bucks later everything was good. Check all your fuses in the mean time until you get it scanned.
2001 Chevy Impala 3.4 - Traded
2004 Chevy Impala 3.4 - Traded
2002 Chevy Impala 3.4 - RIP 1.12.2011/ Ice Storm
1996 Chevy Impala SS - RIP 4.15.2012/ Asswipe
1996 Chevy Impala SS - Current
Crime Scene is offline
post #3 of (permalink) Old 09-04-2011, 10:14 PM
Actually now that im thinking about it, the tps sensor caused my SS to idle like a savaged dog. Soooooo, id really would get that scanned cause unless your car is idling funny, along with your driving symptoms, it may not be the tps.... Hopefully thats all it is.
post #4 of (permalink) Old 09-04-2011, 10:31 PM Thread Starter
sometimes when I start it it'll run like crap for 3 seconds or so, like it can't decide what rpm it wants lol but otherwise the Idle is alright... HOWEVER, I know that when I put it in drive, it'll hit 15-20 mph without touching the gas... that might be throttle cable adjustment though... I forgot to look into that last time someone mentioned it.
The scanner is really nice- my dad is the only one allowed to use it at work so he's allowed to take it home on occasion and he'll just scan our cars real quick for a check up. it's a great (and expensive) tool!
post #5 of (permalink) Old 09-04-2011, 10:31 PM Thread Starter
oh and Kane, I see you got the Law marker on your profile- I was hoping to get you in on this thread too: http://www.impalaforums.com/appearan...w-members.html
post #6 of (permalink) Old 09-05-2011, 01:32 PM Thread Starter
Ok, ran the computer with my car today- this is some of the Data:
first off, it came back with a P1811C code which is for "Maximum Adapt+ Long Shift"
it occurred at:
2157 RPM
216 degrees engine temp (Average)
22MPH
38% Engine Load
22% Throttle
7.39 MSFC- Injector Pulse
the 1-2 shift time (Ran it while driving) is a solid .3-.8 seconds. Wide margin, but it changes. We speculate the band is slipping or something else is sticking.
the code is for low or contaminated trannie fluid- I changed it about a month ago so the code might be left over. I checked today and it needed another quart or so for some reason, so I'm gonna re-scan it in a few weeks after driving and we'll see
Something tells me I'm gonna need a rebuild B/
post #7 of (permalink) Old 09-05-2011, 09:01 PM
Gregg-O's Avatar
So your having shifting issues and hadn't even checked the fluid level. You changed the fluid, and never even checked it after that. ....Come on son, at least do some basic check's before asking for advice. Jeebus.
Gregg-O is offline
post #8 of (permalink) Old 09-06-2011, 02:59 PM Thread Starter
I DID check it... I checked it about 2 weeks ago after running the motor for the proper amount of time) while talking to my dad about looking into it and it was fine, which also raises concern. then yesterday we ran the scan and checked a second time and it was low
Now even with added fluid it's not any better. The code must have been left over from before I changed the filter and fluid.
post #9 of (permalink) Old 02-21-2014, 07:31 AM
Laurieb's Avatar
????? what's the name of the tool used to change the TPS on a Chevy Impala? I am getting ready to buy one online (cause mine is triple what I'm seeing on here) and I need the tools to change it.
Thank you
Laurieb is offline
Replacing Throttle Position Sensor AlfredoSmith Chevy Impala 8th Gen Discussion 13 07-08-2014 10:30 PM
Throttle Position Sensor csherrill 8th Gen Engine Performance 7 11-19-2013 06:44 PM
Check Engine P2138 throttle position sensor los2003 Chevy Impala 8th Gen Discussion 2 08-09-2010 04:05 PM
Throttle Position Sensor RATLIFFD 6th Gen Engine Performance 2 08-14-2009 06:25 PM
could the Throttle Position Sensor give my 01 impala a slow take off and... ronda6729 Chevy Impala Discussion 1 07-27-2008 07:03 PM
