My car loves to stall out!Whats wrong? - Chevy Impala Forums
Go Back   Chevy Impala Forums > General Discussion > Autocare and Maintenance
Old 07-20-2010, 07:23 PM   #1 (permalink)
Nocean's Avatar
I have a 2000 impala 3.4 when the car is started cold it cranks up no problem.But when the engine is warm the car will stall out.I found that if i lightly press on the gas it prevents the car from stalling then right when the battery light goes off i release and am fine.And randomly ill stall out at toll booths and lights periodically anybody gone through this before?
Nocean is offline   Reply With Quote
Old 07-20-2010, 07:59 PM   #2 (permalink)
Gregg-O's Avatar
IAC valve....
Old 07-21-2010, 05:29 AM   #3 (permalink)
Moderator
wanderson75's Avatar
Agreed. Possibly Fuel Pressure Regulator too. But I'd lean more on the IAC.
–adjective
wanderson75 is offline   Reply With Quote
Old 07-21-2010, 12:55 PM   #4 (permalink)
Nocean's Avatar
And Sometimes the idle is really high where it feels like its on cruise control pretty scary.Should i clean or replace the IAC anybody know where its located under the hood
Old 07-22-2010, 05:39 AM   #5 (permalink)
Moderator
Definitely IAC. It's on the side of the throttlebody above the Throttle Positioning Sensor. Prepare to remove the screws with channel locks. You'll see why when you look at it.
Also, save yourself some headaches and replace the screws when you remove them.
–adjective
Old 07-24-2010, 04:47 PM   #6 (permalink)
Nocean's Avatar
Thanks a lot.I went ahead and ordered the part hopefully it will be a smooth install
Any day breathing above the ground is a good day to me brother!
whats wrong with my car? zurg5555 Autocare and Maintenance 12 07-21-2010 07:28 PM
whats wrong with my car? zurg5555 Autocare and Maintenance 2 07-17-2010 08:47 PM
'05 Impala loses power steering but engine does not stall, what's wrong? jtd Chevy Impala Discussion 3 06-04-2008 06:35 PM
whats wrong with my caprice???????????????? FCVS Chevy Caprice 3 05-29-2008 03:07 PM
whats wrong with my caprice? FCVS Chevy Caprice 1 04-29-2008 10:04 PM
