95 impala acting up - Chevy Impala Forums
Go Back   Chevy Impala Forums > General Discussion > Autocare and Maintenance
Old 06-10-2010, 02:10 PM   #1 (permalink)
mrimpalaSS's Avatar
Angry 95 impala acting up
i have a 95 impala ss, and i recently put on a new water pump, coil, coil packs, fuel pump, fuel filter, new cold air intake, and maf sensor. it cuts off randomly from time to time, and/or wont start up at times, i notice that it over heats also. today i drove it and i was going about 45 and it cut off on me, and left me coasting. i pulled over, waited 5min then it started back up, but when it did it imediatly went hot, then i dro e it for a block or 2 then it went back normal, the battery is fine, altinator is fine starter is fine but why would it cut off on me, and somedays randomly dlont want to start? pls help i put alot of money into this and it seems like it wont fix right. what could it be
mrimpalaSS is offline   Reply With Quote
Old 06-10-2010, 03:37 PM   #2 (permalink)
coil, coil packs????
What does that mean?
What MAF did you put on it?
Did you bleed the cooling system?
Old 06-10-2010, 09:13 PM   #3 (permalink)
BAD IMP's Avatar
You either have a coil or coil packs, not both. Does it have a CEL? Any codes? Like Dwayne said, need to make sure the cooling system is bleed good. Air in the system will cause the overheating.
1996 Impala SS DCM, Powerdyne Supercharger 6 psi, 3.73s, Snow Performance Water/Meth injection, Borla catback system, Grotyohann long tube headers, Magnaflow high flow cats, Hotchkis springs, front and rear sway bars, Bilstein shocks, Vigilante 3000 stall TC.
BAD IMP is offline   Reply With Quote
The transmission on my 05 Chevy Impala started acting wierd today. Everytime Kevin Mechanical and Electrical Problems 2 02-22-2009 03:18 PM
blinker acting up Jake123 Chevy Impala 7th Gen Discussion 4 02-02-2009 11:32 AM
my 2004 Chevy Impala temp gage is acting strange? vonnie Chevy Impala Discussion 0 08-13-2008 10:10 AM
