where is the power steering on a 2000 chevy impala V6 3.8 - Chevy Impala Forums
post #1 of (permalink) Old 11-16-2008, 09:01 PM Thread Starter
brenda1486's Avatar
Question where is the power steering on a 2000 chevy impala V6 3.8
where is the power steering on a 2000 chevy impala V6 3.8 I need to check the level because i think is low does any one knows where is located thank you
brenda1486 is offline
post #2 of (permalink) Old 11-24-2008, 04:21 PM
05ss45's Avatar
its on the passenger side right near the firewall, its pretty far down in there with a picture of a steering wheel on the cap..
SLP headers, 3.8/3.5 MPS,v1.0 DHP PCM, Grant built trans, intense I/S, Trans-Go shift kit, 2800 stall(Comp Cams custom grind 2 be installed)
05ss45 is offline
post #3 of (permalink) Old 11-25-2008, 09:07 PM
Riverheadracer's Avatar
all the way down there u need a long neck funnel just to add fluid and a flashlight would be handy
Riverheadracer is offline
post #4 of (permalink) Old 11-26-2008, 03:23 AM
Moderator
04DetroitLS's Avatar
mounted really low on the bock to, so its kind of a pain to find. Flashlight will help, but just follw the belt to the bottom left corner (if standing @ pass side fender) it will be the lowest and last thing you hit You can see it in this pic, right above the oil filter
04DetroitLS is offline
post #5 of (permalink) Old 11-27-2008, 09:40 PM
impalaguru's Avatar
Smile power steering
it's best to get at it from the front. wait till your car cools down and place a towel over the engine. ther is a bar that you have to get past to reach it. it's best to your first two fingrs and your thumb to get it off. also use the long neck funnel from the front too just over wires and it will slide right in.
impalaguru is offline
post #6 of (permalink) Old 10-14-2009, 04:28 PM
Timmyw's Avatar
just so you know
this does not ever come up when you search the site...
I found this 4 hours later in a bing search...
Timmyw is offline
post #7 of (permalink) Old 03-08-2015, 01:07 PM
Charliebrm's Avatar
I know, I know. This is a really old thread but if someone comes across it via a Google search like I did, here is what I picked up from a 2 minute YouTube video today:
Get the coolant reservoir out of the way for more access without a lot of trouble >>>
Remove the two nuts on the strut tower that hold down the tubular cross member that runs from strut to strut. Lift the cross member up and over to the firewall.
Remove the two bolts for the reservoir and ease the container up and to the front of the engine.
Should be able to get a hand down there with room to shine a light.
http://youtu.be/lLi4-cOXsTw
I guess that would help a bunch with handling the serpentine belt replacement too. I have a groaning whine that I think is power steering related. Certainly more pronounced noise at cold temps and when turning out of my parking spot in the mornings in the winter.
Charliebrm is offline
2004 Impala Needs Power Steering Fluid FLImpaladriver Autocare and Maintenance 7 01-30-2010 08:37 AM
2000 chevy impala V6 3.8 where is located the Power steering brenda1486 Mechanical and Electrical Problems 3 12-16-2008 12:24 PM
Stripped flare nut power steering line 1994 chevy caprice? Roxanne N Chevy Caprice 1 04-27-2008 11:46 AM
2003 Chevy Impala Power Steering!? KULJIT S Autocare and Maintenance 1 03-05-2008 06:50 PM
How do you take the power steering pump off on a 2000 3.8 impala? JBDizzle Chevy Impala Discussion 1 12-10-2007 02:31 PM
