Chevy Impala SS Forums
Old 11-09-2008, 02:31 PM   #1 (permalink)
FLImpaladriver's Avatar
Red face 2004 Impala Needs Power Steering Fluid
Remove this ad!
What power steering fluid do I need to purchase?
The manual says GM Power Steering Fluid (GM Part No. U.S. 89021184) but I cannot find it. I even called down to a GM dealership and they didn't know what I was talking about. Also there have been people posting that transmission fluid is the same as power steering fluid which has gotten me further confused. I thought transaxle and transmission fluid are the same but I always thought that power steering fluid is a different fluid. I called down to an autoparts store and asked what power steering fluid to purchase and they said I needed Dexron but in the manual it list Dexron III as the transaxle/transmission fluid. HELP!
FLImpaladriver is offline
Old 11-09-2008, 04:22 PM   #2 (permalink)
77Impala's Avatar
Go to your local auto part store and find a PSF that is compatable with GM vehicles. Most steering fluids are.
From personal experience do not use Tranny or Brake fluid. Most pre 80 cars could take about anything in the steering fluid resivoir and had no problem, but cars after 1980 are way more finicky.
1977 Impala Sedan, 5.0L, TH200, 3.25:1, 82K miles, 27 Lifetime Warranty Parts. Does not like Dodge Pickups rear bumpers!
1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 352K miles, 10 Lifetime Warranty Parts.
77Impala is offline
Old 11-10-2008, 03:41 AM   #3 (permalink)
capricewiz's Avatar
If you can go to the dealer and get yourself a bottle of Cold Climate Power Steering Fluid. You can only get it at the dealer. GM's have a tendency to whine when at a cold start. Otherwise regular power steering fluid is fine, that you'd get from like pepboys or autozone. But I highly recommend the cold climate fluid if its going to be cold where you are this winter.
capricewiz is offline
Old 11-14-2008, 08:26 AM   #4 (permalink)
blusail's Avatar
If you decide to go with the cold climate power steering fluid the p/n on it is 12345867. That should help you out.
blusail is offline
Old 12-14-2008, 09:20 AM   #5 (permalink)
porter's Avatar
for cheap price autoparst and accessories u can go on autopartsway.ca
porter is offline
Old 01-19-2010, 07:29 PM   #6 (permalink)
korbas12's Avatar
Will the cold climate PSF work in warm climates just as well as the regular stuff will?
I live in Florida but if I decided to drive up to Canada or something, I'd like to be able to make the trip without necessarily switching fluids.
korbas12 is offline
Old 01-28-2010, 05:33 PM   #7 (permalink)
green demon's Avatar
Hum, never heard of cold climate power steering fluid,well now you have me thinking,what size container does it come in,is it compatable with regular power steering fluid and what would be the approximate amount that you would need if you drained the ps reservoir and refilled? ed
green demon is offline
Old 01-30-2010, 07:37 AM   #8 (permalink)
I checked 3 local dealers and no one knew anything about such a product. Then I called another Chevrolet dealer parts dept.and the guy sounded less grumpy then the first three. I gave him the part # and he
said "never heard of the stuff" however GM dealers must have a method of
searching other dealers parts inventories,and the guy said, found some at a GM truck dealership. Went down to pick up 2 qts. and used my companies name and got it for $15.00 a qy. What I can tell you so far is that its green in color,has a really funny smell and its made in Canada,thats probably alot more than anyone wanted to know about power steering fluid,but there you have it.
where is the power steering on a 2000 chevy impala V6 3.8 brenda1486 Autocare and Maintenance 5 10-14-2009 03:28 PM
Does the 2004 Impala SS use power steering fluid or transmission fluid for BUBS Chevy Impala Discussion 6 11-14-2008 09:22 AM
How do I bleed air from power steering system in an '03 Impala .? sweetyebug3 Autocare and Maintenance 2 05-28-2008 10:50 AM
2003 Chevy Impala Power Steering!? KULJIT S Autocare and Maintenance 1 03-05-2008 05:50 PM
How do you take the power steering pump off on a 2000 3.8 impala? JBDizzle Chevy Impala Discussion 1 12-10-2007 01:31 PM
