Cleaning Car Battery Terminals - Chevy Impala Forums
 5Likes
  • 3 Post By 04Imp38
  • 1 Post By jtrosky
  • 1 Post By Old Bones
post #1 of (permalink) Old 05-19-2017, 02:30 PM Thread Starter
crawlver's Avatar
Hello all!
Recently, I noticed the slightest bit of build up on my battery terminals and wanted to clean it up. I began looking up how to do this, since I'm still fairly new to DIY car maintenance, but there were all sorts of warnings about losing memory settings when you disconnect the battery, and the possibility of the car running rough while it relearns everything. Since my 2009 is relatively "new" I just wanted to double check.
A few solutions floating around were those battery memory savers with the OBDII port and 12V connector connected to a battery jump starter or battery pack. However, there were some articles saying these things are a really bad idea, and can cause problems with other computer systems.
Is it a real PITA to relearn everything on the Impala or is the only real memory loss the radio presets? What do you guys do when it comes to this maintenance?
The small amount of acid build up is easily visible and would be easy to get off with some baking soda/water, but I want to be thorough!
Thanks, and I appreciate the help!
-Cameron
crawlver is offline
post #2 of (permalink) Old 05-19-2017, 02:38 PM
04Imp38's Avatar
Not to be offensive, but I think you are overthinking this here Yes it is good to clean acid off the terminals, no doubt about it. However, I think the memory saver is a little overkill. I'd be concerned about something it would do to my car's electrical system being that there are many sensitive things connected. I've never seen a car ruined because the battery was disconnected without a holding power source LOL. If you want to get a memory saver that's not an issue but IDK if it's worth all the trouble if something goes wrong. My .02
plano-doug, crawlver and 12 lt like this.
~Joe~
04 Impala LS
Dual Stainless Xlerators
Stainless Xlerator Resonator
4 inch Stainless Tips
ZZP DP
ZZP PCM
ZZP 180 drilled t-stat
Optima Red Top battery
Tubular trailing arms
Police LCA's
Police brakes
Dorman solid sway bar
Many more mods to come!
04Imp38 is offline
The Following 2 Users Say Thank You to 04Imp38 For This Useful Post:
crawlver (05-19-2017)
post #3 of (permalink) Old 05-19-2017, 04:01 PM
Quoted: 342 Post(s)
Agreed - I've disconnected my battery many times - the biggest "issue" that it causes is that I have to reset my favorite radio stations and the time. :-) Don't worry about it for one second...
Although.... It *may* reset the ODB-II readiness monitors - if you live somewhere when you need emissions inspections (and have one coming up), it could take up to a few weeks before the car is ready for emissions inspection (the readiness monitors can take a while to set). Something to consider...
Sent from my Vi10 Plus using Tapatalk
crawlver likes this.
jtrosky is online now
post #4 of (permalink) Old 05-19-2017, 10:55 PM Thread Starter
crawlver's Avatar
Haha well thanks for easing my mind! I'm far away from my next smog, so I'll get it all cleaned up!
Thanks again!
-Cameron
crawlver is offline
post #5 of (permalink) Old 05-20-2017, 07:05 AM
Quoted: 48 Post(s)
Gotta agree with above posts. May be a slight inconvenience to reset radio presets, but much less inconvenient then having a dead battery that quit charging for poor terminal connection or possibly worse.
post #6 of (permalink) Old 05-24-2017, 07:59 PM
retiredpauly's Avatar
Quoted: 119 Post(s)
Actually, my radio presets stayed just fine when I swapped out the battery and did a terminal clean as you are speaking of.
The clock lost its time but the presets remained. Might have something to do with Onstar or XM ??.
The ECM/TCM will learn again pretty quickly. To be honest, I didn't notice any real difference. Idled a bit lumpy on first restart but seemed pretty normal after that. , and next restart was normal.
A word of caution
When loosening the nuts on the terminals be very careful with them. If you drop one or loose it you will not be able to tighten the terminal and you CANNOT BUY them. A silly and foolish design....IMO
retiredpauly is offline
post #7 of (permalink) Old 06-13-2017, 04:20 PM
Preduck's Avatar
I bought a terminal clesning kit with a nice round brush that worked great. Only had to reset the clock and radio presets
Preduck is offline
post #8 of (permalink) Old 06-19-2017, 06:54 PM
Caprice Classic with Class
Old Bones's Avatar
Quoted: 43 Post(s)
If your old school .... wire brush and baking soda
Carbide likes this.
Quadrajet Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Two-way dash-cam. Crazy Canuck behind the Wheel.
Old Bones is offline
Spring Cleaning Essentials for Your Car AutoGuide.com Announcements 0 04-17-2017 09:01 AM
Car Truck Conditioner Air Outlet Dashboard Dust Dirt Cleaner Glue Cleaning Gum RSS Bot Impala Diecast Toys Cars on eBay 0 03-11-2015 06:21 PM
Car Truck Air Outlet Interior Dashboard Dust Hairs Transparent Cleaning Gel Glue RSS Bot Impala Diecast Toys Cars on eBay 0 03-08-2015 07:50 PM
Car Truck Conditioner Air Outlet Dashboard Dust Dirt Cleaner Glue Cleaning Gum RSS Bot Impala Diecast Toys Cars on eBay 0 02-25-2015 05:50 PM
top post to side post (terminals) rangel515 Automotive Discussion 2 04-11-2011 11:06 AM
