Radiator flush - Chevy Impala Forums
post #1 of (permalink) Old 01-08-2017, 02:11 AM Thread Starter
Joeboxer1130's Avatar
Radiator flush
Any tips on how to properly remove all the water from a 2001 impala? Bought the car and didn't't have any coolant just filled with water. I wanna add the proper coolant, and saw on some videos that distilled water should be used to drain. What hose do I remove to drain it complete or most of it. Motor is 3.4
Thanks in advance.
Joeboxer1130 is offline
post #2 of (permalink) Old 01-08-2017, 02:12 AM Thread Starter
And should I add some antifreeze during this process?
post #3 of (permalink) Old 01-17-2017, 10:31 AM
daman's Avatar
If the car is filled with ONLY water just drain the radiator completely, then refill the radiator with pure(100%)coolant not 50/50, run/drive the car so everything circulates well(heater on hot)till operating temp is reached. Stop car let cool completely, test coolant with tester and adjust from there if too strong drain some out add water if too weak drain some add coolant.
Try to shoot for -10 to -15 is plenty.
2004 LS 3800
Mobil 1 0w30
Valvoline Dexron-VI ATF/Magnefine ILF
daman is offline
post #4 of (permalink) Old 01-17-2017, 09:30 PM
04Imp38's Avatar
Quoted: 25 Post(s)
There is a drain plug on the bottom driver side of the radiator; it may be very hard to get out. Sometimes taking the lower hose off of the radiator is easier.
~Joe~
04 Impala LS
Dual Flowmaster Super 44s
Vibrant Resonator
ZZP DP
ZZP PCM
ZZP 180 drilled t-stat
Optima Red Top battery
Tubular trailing arms
Police LCA's
Police brakes
Dorman solid sway bar
Many more mods to come!
04Imp38 is offline
Radiator Flush n1k1peterson Autocare and Maintenance 1 01-02-2016 10:18 PM
coolant flush how to ponch37300 Chevy Impala 7th Gen Discussion 8 11-27-2014 12:43 AM
2000-2005 3400&3800 Radiator flush & bleeding the air Stephen "DIY" Do it yourself/how to 7 03-23-2014 12:50 AM
trans flush timji Chevy Impala 7th Gen Discussion 25 05-09-2012 11:20 AM
Coolant Flush trainedsnypa Chevy Impala 8th Gen Discussion 14 02-08-2012 08:14 PM
