added factory foglights, indicator light possible? - Chevy Impala Forums
post #1 of (permalink) Old 12-15-2012, 11:05 PM Thread Starter
sohrn's Avatar
I just installed factory foglights in my 06 impala ls, bought a new headlight switch to work off factory button..No factory wiring for any of it so made the harness. They work fine but was wondering if anyone knew how i could get indicator light on dash to work. Thanks
sohrn is offline
post #2 of (permalink) Old 12-16-2012, 06:25 AM
Back in Black
12ltz's Avatar
Are you using a factory headlight switch or aftermarket switch?
If aftermarket you can get switchs that light up when on both toggle,pushbutton and rocker switch types. Last one I did was 5 years ago found lighted toggle at radio shack because it was closes and I could get it then but check the web there are lots of options out there.
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
post #3 of (permalink) Old 12-16-2012, 06:40 AM
auntjemima's Avatar
They want it to say fogs on the instrument cluster I think. I don't have fogs so I am unsure if it usually shows fogs on the cluster when they are engaged.
auntjemima is offline
post #4 of (permalink) Old 12-16-2012, 08:18 AM
Back in Black
12ltz's Avatar
little weird light shows up in upper right hand corner of cluster on my 2012 but the 2002 Regal only lite up the switch.
12ltz is offline
post #5 of (permalink) Old 12-16-2012, 11:00 AM Thread Starter
sohrn's Avatar
I bought the factory headlight switch with the fog light button. I know it has a light on the cluster on the left hand side, i can see the picture but i know the computer controls it and because i have an ls wiring is not there from computer. I will have to hook up little light somewhere but just would have liked to have it work like factory.. someone told me all indicators on cluster run off one wire, so prolly different resistances. Just didntr know if anyone has tried to get it to work
sohrn is offline
post #6 of (permalink) Old 12-16-2012, 11:22 AM
Back in Black
12ltz's Avatar
somebody with a tech2 might be able to program it, not sure but no harm in asking
12ltz is offline
post #7 of (permalink) Old 12-16-2012, 11:42 AM Thread Starter
sohrn's Avatar
yeah i got a buddy that works for chevy and he thinks i need to change the computer.. not worth that.. guess ill just add a little indicator somewhere..
sohrn is offline
post #8 of (permalink) Old 12-18-2012, 12:16 PM
$ILLK
asilkyg30's Avatar
Send a message via Yahoo to asilkyg30
@sohrn
Keep us posted on your progress please. I plan on swapping my front bumper to one with fogs this next year and would like to know how you set it up?
Thanks
2008 Impala LT
asilkyg30 is offline
post #9 of (permalink) Old 12-18-2012, 03:29 PM Thread Starter
sohrn's Avatar
sohrn is offline
The Following User Says Thank You to sohrn For This Useful Post:
asilkyg30 (01-02-2013)
post #10 of (permalink) Old 12-18-2012, 03:34 PM Thread Starter
sohrn's Avatar
Thats how i did it and most reliable.. I got the dei611t right on ebay for like 20 bucks.. If you add the headlight switch with foglights you have to add the wire to harness at pin 6.. works like a champ just trying to figure out the light on cluster still because of it would be nice to have an indicator but will update on that, I bought the front bumper, fog lights and surrounds, and 2 pigtails for the lights and just made the harness..
sohrn is offline
post #11 of (permalink) Old 05-15-2015, 12:45 PM
metalmike187's Avatar
May I ask which one is pin 6? How do you determine which one is pin 6 on the harness?
metalmike187 is offline
post #12 of (permalink) Old 05-16-2015, 09:04 PM
carlos64030's Avatar
Quoted: 17 Post(s)
On the back side of the plugin for the headlamp switch are numbers stamped into the plastic. There are 16 pins. The top row has a #1 on one end and #8 on the other. On the bottom row, there's a #9 on one end and #16 on the other. Those are your reference points and it's easy to figure out which pin is which.
1 8
_____________
9 16
carlos64030 is offline
post #13 of (permalink) Old 12-14-2015, 06:28 AM
dgoldsborough34's Avatar
Hey, Im new to this forum. I went onto the BB engineering website and they said they are closed. Im trying to do exactly what you did to your Impala LS by wiring my aftermarket foglights to the stock OEM switch. How did you do it? Where can i order the parts?
Originally Posted by sohrn View Post
dgoldsborough34 is offline
post #14 of (permalink) Old 12-14-2015, 07:31 AM
Quoted: 289 Post(s)
If I understand it correctly, the only "parts" you need are the correct headlight switch (with the fog light switch in the middle) and the DEI-611T module, which you can still buy on Ebay... You already have what you need from BBE - which is the design they came up with and is shown in your attachment.
At least that is my understanding...
post #15 of (permalink) Old 12-14-2015, 07:31 PM
KG2014's Avatar
Quoted: 55 Post(s)
Didn't know there was something out there about this. Seems pretty simple. Might do this over the summer.
Yeah I got a few mods.......
Check out my mod thread here
Check out my garage here
KG2014 is offline
WTB pair of 00-05 Impy foglights & surv. switch pbNJ Private Wanted Classifieds 1 09-09-2012 10:39 PM
why is my change oil indicator on??? Shaft Chevy Impala 8th Gen Discussion 5 06-10-2011 07:21 PM
Oil change indicator light griffenspade Chevy Caprice 7 03-12-2010 02:07 PM
Added New !! solo Introductions & Welcome Forum 5 01-11-2010 03:39 PM
