Reverse light wire - Chevy Impala Forums
post #1 of (permalink) Old 11-18-2012, 09:42 AM Thread Starter
Bgsmith319's Avatar
Reverse light wire
Hi I have a 2002 impala ls 3.8. I am installing a rearview backup camera and I can't find out which wire is the reverse lights wire. I found the reverse light relay on the passenger side of the vehicle but I can't get it out or figure out the color. I'm trying to connect this wire ASAP as I'm going out if town in a couple days. Please help. Thanks
Bgsmith319 is offline
post #2 of (permalink) Old 11-18-2012, 11:28 AM
463
463's Avatar
lite green as the wire leaves the right i/p juction block.
thats where the relay and 10 fuse are located.
Welcome to the forum
463 is offline
post #3 of (permalink) Old 11-18-2012, 11:37 AM Thread Starter
Bgsmith319's Avatar
Reverse light wire
There is a lite green wire and then there is a lite green wire twisted with another wire. Do u know which light green wire. I can't get to the back of the fuse block
post #4 of (permalink) Old 11-18-2012, 03:54 PM
463
463's Avatar
I would think that the single lite green wire would be the one but i can't say for sure.
On the wire dia it shows on down the wire to the rear a connection point called S901 where the wire splits into two wires for the left and right lamps.
You might be able to do a test for 12volt at that connection and then back trace the wire.
Does the car have a electromic mirror ?
it shows in the cir a dark blue wire from the BCM to the back up relay that runs the mirror and back up lamps.
As the options add on the wire dia change.
463 is offline
post #5 of (permalink) Old 11-18-2012, 06:39 PM Thread Starter
Bgsmith319's Avatar
U know what. I think the other lite green wire that's twisted with another wire, I think the other wire is a dark blue. So if that's the case does that mean the single lite green wire is the one I need?
post #6 of (permalink) Old 11-18-2012, 07:22 PM
463
463's Avatar
If car has a electromic mirror
From the relay out there would be power to the mirror and backup lights.
test that wire with a digital volt meter for 12 volt when in reverse and see if thats 12 volts.
463 is offline
post #7 of (permalink) Old 11-19-2012, 07:49 PM Thread Starter
Bgsmith319's Avatar
i know this is rediculous but i have no way of testing the wires. but there is only 2 lite green wires and one of them is twisted and the other one is not. does anyone happen to know if its the twisted lite green wire or the lite green wire that isnt?
post #8 of (permalink) Old 11-19-2012, 07:55 PM
auntjemima's Avatar
Go to an electrical store and ask for a small connector that allows you to tap into a wire. I will take a picture of what I mean tomorrow if you don't get to it then. What this does is allow you to tap the wires power without having to cut the wire so you can test it before you splice into it.
auntjemima is offline
post #9 of (permalink) Old 11-20-2012, 11:05 AM Thread Starter
Bgsmith319's Avatar
Ok thanks
post #10 of (permalink) Old 11-20-2012, 01:04 PM Thread Starter
Bgsmith319's Avatar
Any updates on information about the wiring.
post #11 of (permalink) Old 11-20-2012, 04:32 PM
463
463's Avatar
does the car have a electromic mirror (auto dims at night )?
463 is offline
post #12 of (permalink) Old 09-11-2013, 02:43 PM
larryj845's Avatar
how did the install come out because im looking to do the same thing but i cant find the wire im supposed to tap into
larryj845 is offline
post #13 of (permalink) Old 09-11-2013, 03:24 PM
463
463's Avatar
the posters Last Activity was on: 11-21-2012 09:03 AM
I could have a look on the wire diagram but I need information on your car.
463 is offline
post #14 of (permalink) Old 09-11-2013, 05:41 PM
larryj845's Avatar
2002 chevy impala ls v6 3.8
post #15 of (permalink) Old 09-11-2013, 07:57 PM
463
463's Avatar
A light green as the wire leaves the right hand inside fuse junction block.
that is where the relay and 10 amp fuse for the back up light are located.
so look for the light green wire leaving the back of fuse block.
The dark blue wire from the relay gets to energize the relay when the key is in the run and in reverse.
463 is offline
The Following User Says Thank You to 463 For This Useful Post:
tre6jj (04-27-2014)
Reverse LED Lights?? Base32 Appearance 4 06-13-2012 04:12 PM
66 Impala with 20" Reverse offset Goody_357 1st - 5th Gen Suspension 0 03-23-2011 05:18 PM
reverse lights& tag light Fatkid Chevy Impala Discussion 2 01-10-2011 09:14 AM
HELP 66 Biscayne- 4 speed- reverse light switch? bisqwik427 Chevy Impala Discussion 1 08-23-2008 06:48 AM
My truck won't go in reverse!!!? Jaileen Automotive Discussion 0 09-17-2007 02:15 AM
