New to car audio, Read here! - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 01-09-2013, 04:43 PM
bemo's Avatar
Great information. Thanks! One question though, does it not matter what the level of the test tone on the recording is? I see one test CD with a test tone at -10dB and another with a tone at -20dB.
bemo is offline
post #17 of (permalink) Old 01-14-2013, 07:23 AM
bemo's Avatar
I'm trying to set the gain for a subwoofer amp. A couple of other questions: Should I somehow account for my radios speed adjusted volume? My sub amp (Polk 400.1) has a remote volume/gain control. Should I set the gain with this disconnected or with it connected? If connected, should I set it to max? Thanks for any guidance.
bemo is offline
post #18 of (permalink) Old 02-26-2013, 12:37 AM
markymark3130's Avatar
This is a lot of really good information. There is one thing I think I didn't see though and that is the importance of CEA-2006 compliance. If you see that sticker on a box, then you know 100% that the ratings of that amplifier are accurate. If the amp or sub is not CEA-2006 compliant than the manufacturer can put whatever rating they want on that box. I'm not trying to say that brands that aren't CEA-2006 are junk but for beginners it's must better to be safe than sorry.
markymark3130 is offline
post #19 of (permalink) Old 03-20-2013, 04:23 AM
blackrosetiger's Avatar
You forgot Knuconcepts for wiring lol
blackrosetiger is offline
post #20 of (permalink) Old 06-02-2013, 01:26 AM
Mike1990's Avatar
Whats the best fuse to use on my 00 impala LS for connecting it to the amp?
Mike1990 is offline
post #21 of (permalink) Old 06-02-2013, 02:00 AM
SCOTTYINWV's Avatar
What is the Amp Brand/model? What are the specs for the amp? Are you talking about the main power source from the battery?
SCOTTYINWV
SCOTTYINWV is offline
post #22 of (permalink) Old 12-01-2013, 08:54 PM
sherrie0769's Avatar
Thank YOU!!!
sherrie0769 is offline
post #23 of (permalink) Old 01-08-2014, 10:25 AM
slickmastajay's Avatar
Wow so much information! In order to avoid making a new thread I figured why not ask here.
I have a 1100 rms 1ohm stable amp. I have a driver that likes 700rms. In order for me to give it 700, i would have to use a multimeter and slowly turn the gain clockwise until I get it to read 26.46 volts?
Also regarding the big 3 upgrade, I see that the 7th gen has many wires that are in loom tubing and go to the battery. I want to make 100% sure that its OK to just add the 1/0 awg instead of replacing the stock wiring to the battery and alternator?
slickmastajay is offline
post #24 of (permalink) Old 02-20-2014, 08:26 PM
Bigboy's Avatar
Quick question? On my 04 impala ls my sound quality is poor at times.like I can have it on medium and
It bearly sounds as if it is on and for having the factor y amp it doesnt thump nor sound really loud.
Is it the head unit? Should I bypass the amp? Plz help and thanks.
Bigboy is offline
post #25 of (permalink) Old 02-25-2014, 09:22 PM
Quoted: 51 Post(s)
Very likely the amp. Factory amps in the 7th gen are junk. You'd be better without it, unfortunately bypassing in an 02 and later 7th gen isn't an option for novices.
The best (IMO) way to fix it would be to replace the headunit, amp, and speakers with aftermarket.
The next option is to replace it with another factory amp (bad option IMO)
Then you could try and run new wiring from an aftermarket headunit to either the stock or aftermarket speakers. This will work, but it won't be as good as the full system.
*2001 Impala Ls - 129k
*2000 Blazer 4x4 - 174k
Winter daily
*1977 C10 - Work in progress
*2014 Impala LT Limited - 35k
RYD SLO is offline
Chevrolet : Caprice ****1975 caprice convertible**** READ READ READ PLEASE RSS Bot eBay Cars For Sale: Caprice 0 09-04-2010 07:11 AM
Please Read, Me And My 95 Ss Need Your Help aprosa5t Chevy Impala 6th Gen Discussion 7 06-30-2009 03:59 AM
Please Read, I Need Your Help aprosa5t Automotive Discussion 9 06-25-2009 10:23 PM
