-   Audio, Video, and Electronics (http://www.impalaforums.com/audio-video-and-electronics/)
-   -   How to Add Subwoofer in trunk with amp for it? (http://www.impalaforums.com/audio-video-and-electronics/317921-how-to-add-subwoofer-in-trunk-with-amp-for-it.html)
Jetripplef 05-22-2013 06:25 PM
Originally Posted by C.E.Divine (Post 460830)
Read through this
http://www.impalaforums.com/audio-vi...tegration.html
I posted youtube videos showing where to run the power wire, and getting to the back of the factory stereo to add in the line out converter. Go on sonicelectronix.com, and search for a pac AOEM-GM1416 line out converter if you don't have bose, or AOEM-GM1416A if you have bose. It is plug and play, so you don't have to cut into your factory wiring to add an amp. That way, if you ever sell the car, you can convert back to factory with no trace you ever had an amp.
The converter has speaker wire passthroughs as well, so you can use the factory speakers, and then use the rca outputs to run the amp. If you only need the one channel of rca's fir the amp, use the rear channel for the amp. That way, the front channels have their full power going to the front speakers.
If you have any more questions, feel free to pm me. I can take you from start to finish on a whole sound system on your car.
Watched the videos but either didn't get to the part of you plugging in the Amp RCA wires or i Missed it.
But is it just like installing it with an aftermarket head unit?
you only plug in the amp to 2 of the rca connectors and the other 2 are left alone?
I am just trying to figure out exactly what i need to do. Have installed many in my time but never one to a stock head unit in a headache of a car like my impala haha.
beast50 05-27-2013 01:26 AM
Originally Posted by dsmith2010 (Post 504226)
i have my 2011 ltz impala hooked up with the PAC oem-gm1416 and it works very well with the bose system, it works amazingly well, no issues, great sound and makes xm radio even better since there is actually bass with it
same here, 2011 LT with BOSE, no problems :ok3:
beast50 05-27-2013 01:29 AM
Yes, I used the rear RCA's on the PAC unit to drive my amp. I have a mono amp and 1 sub.
g25racer 05-29-2013 09:57 PM
Easiest and safest way to get remote turn on or constant power. Find a circuit in the fuse box that turns on with ignition or has power all the time. I have numerous fuse-taps in my car for various uses.
These basically add a fused 12v power source from a fuse slot. There are cheaper ones that just use a piece of bent metal but, those are NOT fused.
RYD SLO 05-30-2013 11:06 AM
Amazon.com: ATM Add-A-Circuit (same function as Bussmann BP/HHH), ATM Fuse Tap: Musical Instruments
Can't get remote turn on with these in the 8th gen, but they are certainly the easiest (and most easily reversible) way to do it
g25racer 05-30-2013 11:56 PM
That's right I forgot. Can you please tell me why?
RYD SLO 05-31-2013 05:35 AM
All of the fuses in the 8th gen are always hot. I believe you need to tap into the RAP relay for switched power
g25racer 05-31-2013 10:46 PM
Gotcha. That's crazy :ok3:
GEEMEZ 02-15-2014 12:00 PM
Where can I find a wiring diagram for my stock radio for my 2011 impala LT?
lyman 04-23-2015 06:24 PM
I have a 2012 impala and I just added a subwoofer/amp combined to the trunk I have my remote wire tapped into my factory OEM remote wire is OK to tap into the 12v power wire for the stereo its self
blackout06 04-24-2015 07:11 AM
PAC oem-gm1416 will it work with an 06 pala bose system
Casper 05-03-2015 01:31 PM
I installed the PAC Gm1416A on my 2009 impala that had bose, it does NOT work! the radio won't even power on with this unit connected. I am waiting on the 1416 to see if that one works. Will post an update with results when i get it.
Casper 05-09-2015 04:26 PM
Update: just finished my install on 2009 impala. I have Bose system and onstar, use GM1416 (no A). Works like a charm.
T's06ss 12-25-2015 09:34 PM
I've been reading a lot of the threads and posts on this forum and i've seen a couple different people point out that the GM-PACAOEMGM1416A doesn't actually work with my 06 impala ss with bose? Is this true? Any help would be greatly appreciated,
Merry Christmas!
KG2014 12-25-2015 11:15 PM
You need the one WITHOUT the A for it to work for your car
