2003 Impala Aftermarket radio install help - Chevy Impala Forums
post #1 of (permalink) Old 11-20-2011, 06:16 PM Thread Starter
Duckdogpig's Avatar
Exclamation 2003 Impala Aftermarket radio install help
I tried to install a radio in my Impala not to long after i got it. As soon as we gave it power the headset would turn on and everything would be good but as soon as we tried to play something no sound would come out. Is there an easy solution that wont cost me $150 for a module?
Duckdogpig is offline
post #2 of (permalink) Old 11-20-2011, 06:58 PM
systemcheck2006's Avatar
u hook up a blue rem wire?
then you'd be normal."
systemcheck2006 is offline
post #3 of (permalink) Old 11-20-2011, 07:44 PM Thread Starter
Duckdogpig's Avatar
I followed everything in the headset instructions, so I believe so. Does it have something to do with the stock amp in the back? If so how do i bypass it?
post #4 of (permalink) Old 11-20-2011, 08:01 PM
i'd double check the wiring, might have something switched around like positive and negetive, maybe speaker wire not hooked up and check connection with amp
post #5 of (permalink) Old 11-21-2011, 03:35 PM Thread Starter
Duckdogpig's Avatar
Alright. Thank you. I will reply again if it does not work.
Not my chair not my problem, thats what I say
post #6 of (permalink) Old 11-23-2011, 04:15 PM Thread Starter
Duckdogpig's Avatar
Everything was hooked up correctly we went through the instructions multiple times. The headset would power up just no music would play out of the speakers.
post #7 of (permalink) Old 11-23-2011, 06:44 PM
did you splice the wires or buy a wire harness
post #8 of (permalink) Old 11-24-2011, 09:26 AM Thread Starter
Duckdogpig's Avatar
we bought a wire harness.
post #9 of (permalink) Old 12-01-2011, 12:06 AM
Beefy's Avatar
The white wire in the Factory harness needs to be spliced into, and hooked up to the blue wire with a white stripe in the deck for the stock amp to turn on (Thats the remote wire that signals the amp with the ignition). with out the interface harness you loose doorchimes, oil light and all the computer stuff thats ran through your stock head unit.
Truth is easiest way to do it is buy the harness I got mine for 99.99 at best buy.
Beefy is offline
post #10 of (permalink) Old 12-01-2011, 12:19 PM
VTSS's Avatar
I used the Scosche GM06B harness to relocate the factory radio in the trunk. It gives you a wiring harness at the dashboard to wire your new head unit into, along with an accessory turn on wire.
http://www.sonicelectronix.com/item_...M06B-GM06.html
VTSS is offline
post #11 of (permalink) Old 12-01-2011, 12:25 PM
Beefy's Avatar
Yeah totally should work. Still way easier to get the interface harness.
Beefy is offline
post #12 of (permalink) Old 02-17-2012, 12:41 AM
below_radar's Avatar
below_radar is offline
post #13 of (permalink) Old 02-15-2013, 08:43 PM
Peanut79's Avatar
HELP...I have a 03 Impala and I went to install a new scosche radio. I cut off my wiring harnesss from my stock radio how do I do it...PLEASE HELP
Peanut79 is offline
post #14 of (permalink) Old 02-18-2013, 07:27 PM
Beefy's Avatar
wait wait wait, did you just say you cut off the factory harness?
Beefy is offline
post #15 of (permalink) Old 02-19-2013, 01:31 AM
g25racer's Avatar
Yeah not a good idea. Need to use a harness adapter. Also I would stay away from scosche anything. FYI scosche only makes one radio which, I doubt you have
controlFREQ | by Scosche
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
'07 SS aftermarket stereo install help stevecon1 Audio, Video, and Electronics 5 07-22-2010 08:23 AM
want to install aftermarket tachometer,but don't know where to ............... stattoninc.com Chevy Impala 7th Gen Discussion 3 07-06-2010 07:36 AM
how to install aftermarket grill tonymont Appearance 1 06-02-2010 10:33 PM
2004 Impala aftermarket radio install Question????? Satanz Impala Chevy Impala 7th Gen Discussion 1 10-13-2009 11:34 AM
Do I have to install an aftermarket cd player in order to install subs in an 02 vanvark83 Audio, Video, and Electronics 4 09-03-2007 07:08 PM
