My 2007 Impala - Chevy Impala Forums
post #1 of (permalink) Old 01-22-2017, 01:13 PM Thread Starter
techchef's Avatar
My 2007 Impala
I have a 2007 Chevrolet Impala LTZ. I bought it used. I can not seem to get the radio to switch over to XM radio. I have the antenna on my roof, and the trunk has the XM receiver (or what seems to be)...I have it activated on a 2 month trial basis and nothing comes through..I push Band and it goes between AM and FM.
Linked below is a picture of the car (you can see the XM antenna)
and
The XM receiver that is in my trunk
techchef is offline
post #2 of (permalink) Old 01-22-2017, 01:31 PM
Revo2Maxx2016's Avatar
Quoted: 78 Post(s)
Wonder if your car had the unit replaced with one that isnt xm compatible? Does your unit have the cat button above eject?
Should be pressing the band button to get to xm stations. Did you look to see if there was a way to turn it on or off? Any after market wiring done like after market amps?
Sent from my VS880 using Tapatalk
James
Revo2Maxx2016 is offline
post #3 of (permalink) Old 01-22-2017, 01:35 PM
Quoted: 286 Post(s)
How did you get the XM ID to activate it? Did it show on the radio display (it should have). If the radio display showed the XM ID, then the radio is definitely XM-compatible. If you had to read the XM ID off of the XM tuner in the trunk, then you probably don't have the correct radio installed (for whatever reason).
Sent from my A1160 using Tapatalk
jtrosky is online now
post #4 of (permalink) Old 01-22-2017, 01:36 PM Thread Starter
techchef's Avatar
I do have a cat button above eject...Now that you are saying about that-there are wires, under my backseat-when i flip it up-they are cut, but they are thick as hell, and are ground wires. When I push CAT it says XM Feature. But when I push Band it goes from FM to AM...I do have XM favorites on my favorite list-but none work.
techchef is offline
post #5 of (permalink) Old 01-22-2017, 01:37 PM Thread Starter
techchef's Avatar
I used my VIN instead-it has an activation feature through Sirius XM using the VIN
techchef is offline
post #6 of (permalink) Old 01-22-2017, 01:38 PM Thread Starter
techchef's Avatar
And-When I talked with someone from SiriusXM they gave me my radio ID-and its LAWUN08W-which is the last digits on the sticker in the trunk unit.
techchef is offline
post #7 of (permalink) Old 01-22-2017, 01:44 PM
Quoted: 286 Post(s)
So you can't get the XM radio ID to show on the radio display? You should be able to. If you can't even see Radio ID on the radio screen then it sounds like there might be something wrong with the radio - or the radio isn't communicating with the XM radio in the trunk for some reason... It sounds like you have the correct radio though. Strange.
Pressing the Band button should definitely take you to the XM tuner - even if not activated (that's how you get your XM radio ID - by switching to the XM band before activated).
post #8 of (permalink) Old 01-22-2017, 01:50 PM Thread Starter
techchef's Avatar
That is correct. Unable to access my ID on the radio. Bought the car used-and chevy wants 125.00 to just look at it-plus w/e it costs to fix it
techchef is offline
post #9 of (permalink) Old 01-22-2017, 01:55 PM
Quoted: 78 Post(s)
IT almost sounds like someone has put in a Aftermarket system in your car in the past. THe big wires you were talking about may have been for the Aftermarket Amp.. So it could be that the person that did the install didn't do it nicely and may have bypassed your extra wiring for your cars XM...
You may want to look in the trunk make sure the plug is plugged in. Also look behind the radio and make sure all is connected back... It could be that the person that did the install in the past cut out the wiring. Then the person to make it work only got the wiring for the normal radio... Sadly not everyone is kind when doing installs and don't do them to make sure they can replace stock radio back to factory specs when they want to sale the car....
James
James
post #10 of (permalink) Old 01-22-2017, 02:06 PM
Quoted: 78 Post(s)
Sorry having computer issues. That is only half my answer lol.... For your radio to XM there should be 5 wires running between them...
Left Audio + Brown/White
Left Audio - Dark Green
Right Audio + Dark Green/White
Right Audio - Grey/Black
Another Dark Green is GMLAN Low Speed data
__________________________________________________ ____________
Then on the XM there should be Red/White for power
Black/White for ground
Also plugged in should be the Coax for the antenna.
James
James
post #11 of (permalink) Old 01-22-2017, 02:15 PM Thread Starter
techchef's Avatar
James
I'll have to have a look at that then thanks!
techchef is offline
post #12 of (permalink) Old 01-22-2017, 02:22 PM
Quoted: 78 Post(s)
Behind your radio you could have plugs like this and maybe they cut them out and only replaced the ones that make the radio work...
Also the wires would be twisted together so it would be not to hard to find the data Dark Green from the other one related to signal
James
post #13 of (permalink) Old 01-25-2017, 02:22 PM Thread Starter
techchef's Avatar
Took radio out-checked wires-No go...
techchef is offline
post #14 of (permalink) Old 01-25-2017, 02:55 PM
NY13LTZ's Avatar
Quoted: 38 Post(s)
techchef, I am no electronics wiz but if it turns out your radio is bad I have the factory stock radio which I removed from my 13 LTZ I'd be glad to give to a fellow forum member. Also just a quick note here, Jtrosky, and myself, and others have been upgrading our radios to the Rosen GM PD1010 radios with nav. They can be found on eBay from a seller called Memory-U. Usually around $150.00 for radio, Bose harness, and GPS antenna. Search "Rosen" in the forums and the thread should be listed.
NY13LTZ is offline
The Following 2 Users Say Thank You to NY13LTZ For This Useful Post:
techchef (01-27-2017)
post #15 of (permalink) Old 01-25-2017, 03:02 PM Thread Starter
techchef's Avatar
Much appreciated-I contacted a friend at Chevy and waiting to hear back from them-seeing if its something obvious i am missing...If it comes down to being a shit radio-I may take you up on that offer...
techchef is offline
Jeff gordon #24-2007 impala ss cot-owners elite-1 of 2007-1:24-see description RSS Bot Impala Diecast Toys Cars on eBay 0 05-12-2014 03:00 PM
Jeff gordon #24-2007 impala ss cot-owners elite-1 of 2007-1:24-see description RSS Bot Impala Diecast Toys Cars on eBay 0 05-09-2014 02:10 PM
Jeff gordon #24-2007 impala ss cot-owners elite-1 of 2007-1:24-see description RSS Bot Impala Diecast Toys Cars on eBay 0 05-06-2014 02:50 PM
jeff gordon #24 dupont 2007 impala ss cot owners elite. 1 of 2007 RSS Bot Impala Diecast Toys Cars on eBay 0 05-11-2013 05:50 PM
NASCAR~MA 2007 1:24~ #29 Kevin Harvick 2007 Impala SS COT~MINT IN BOX RSS Bot Impala Diecast Toys Cars on eBay 0 11-17-2012 12:50 PM
