2015 Impala transmission slipping - Chevy Impala Forums
9th Gen Drivetrain Transmissions, Clutches and Axles.
post #1 of (permalink) Old 08-24-2016, 10:43 AM Thread Starter
Bryn7472's Avatar
I have a 2015 Impala with almost 18,000 miles on it now. The last week I have noticed that anytime the transmission goes from 3rd to 4th gear the rpms rise by a few hundred before it will switch. This causes a delay in switching gears. It will do it no matter how I accelerate. I have the trifecta tune but don't think this is the cause as it will still do it when I engage cruise control(tune off). Am I the only one experiencing this issue?
PS. I have the 3.6l v6.
Bryn7472 is offline
post #2 of (permalink) Old 08-24-2016, 03:07 PM
ICUBB's Avatar
Quoted: 43 Post(s)
I have caught a slip or 2 with only 5k, when it happens as you described it seems the tranny is confused and doesn't react well till it slams into gear. Unless you can get it to reproduce this error I'm guessing Chevy will just ignore you. If you can reproduce it get it to the dealer soon.
http://www.impalaforums.com/signaturepics/sigpic129377_1.gif
Just a resident noob.
ICUBB is online now
post #3 of (permalink) Old 08-24-2016, 06:14 PM Thread Starter
Bryn7472's Avatar
I'm going to get an appt set up for next week. It does it every time now. Will see what they say.
Bryn7472 is offline
post #4 of (permalink) Old 08-26-2016, 08:22 AM
1954 Chevy's Avatar
Get ready (...have a tune).
1954 Chevy is offline
post #5 of (permalink) Old 08-26-2016, 08:28 AM
Quoted: 355 Post(s)
Thankfully, the Trifecta tune is "invisible". So unless you tell them you have a tune, they won't know.
That being said, I would put the stock tune back on before taking it to the dealership. That will also tell you for sure whether or not it's tune-related or not.
jtrosky is online now
post #6 of (permalink) Old 08-26-2016, 09:33 AM
Supporting Vendor
WOT-Tuning's Avatar
Quoted: 4 Post(s)
Always flash back to stock using our solution when going in for dealer service to ensure a trouble free visit. It takes 15 minutes
TRIFECTA Direct Reseller
2014+ Impala 3.6L: +14 ft-lbs and +20 WHP
2012--2013 / 2014+ Impala Limited 3.6L: +6 ft-lbs and +11 WHP
Visit http://www.trifectaperformance.com to order your TRIFECTA calibration today or email info@trifectaperformance.com for more information.
Make sure to like us on Facebook:
TRIFECTA PERFORMANCE
WOT-Tuning is offline
post #7 of (permalink) Old 08-26-2016, 10:01 AM
Quoted: 73 Post(s)
So the OP has a modification done to his vehicle which may have affected his transmission. Clearly he has violated the terms of his new car and power train warranty.
You want him to "flash back to stock" so GM will have to pay for the damage? That sounds like fraud to me.
post #8 of (permalink) Old 08-26-2016, 12:14 PM
ICUBB's Avatar
Quoted: 43 Post(s)
And we ALL already paid to bailout GM's ass. Your point? If the tranny wasn't so poor to start with most wouldn't even consider a tune. Troll away.........
jjj likes this.
ICUBB is online now
post #9 of (permalink) Old 08-26-2016, 06:19 PM Thread Starter
Bryn7472's Avatar
I will definitely be going back to stock with it before it goes in next Friday. This isn't a car that's driven hard either, so hopefully it's a simple fix.
Bryn7472 is offline
post #10 of (permalink) Old 09-11-2016, 12:34 AM
LilRandySavage's Avatar
Quoted: 38 Post(s)
i would have ditched the tune as soon as it started acting up.
LilRandySavage is offline
post #11 of (permalink) Old 09-14-2016, 06:30 AM
bignick2015's Avatar
Quoted: 12 Post(s)
Never noticed a 3-4 slip but sometimes the shifts are slow in general.
First thing I would check is the fluid level, there is apparently a dipstick for it but the manual says this:
There is a special procedure for checking and changing the transmission fluid. Because this procedure is difficult, you should have this done at your dealer service department. Contact your dealer for additional information or the procedure can be found in the service manual. To purchase a service manual, see Service Publications Ordering Information on page 13-11.
I think I read earlier on the forum that with a COLD IDLING engine, the fluid should barely touch the bottom of the dipstick - but I can't recall if this is for 8th or 9th gen cars with the six-speed auto.
2013 Summit White Impala LT
bignick2015 is offline
post #12 of (permalink) Old 09-14-2016, 06:35 AM
Quoted: 355 Post(s)
^^That was definitely in reference to the 8th gens with the same 6-speed trans. Whether or not is also works on the 9th gens, I can't say for sure. You'd think it would work though since it's the same trans.
Is there actually a dipstick on the 9th gens?
post #13 of (permalink) Old 09-14-2016, 06:45 AM
Quoted: 12 Post(s)
The top image shows the V6 and the bottom one shows the I4. On the V6, number 6 is listed as "Transmission Fluid Cap and Dipstick (Out of View)." in my 2015 manual. On the I4, it's just listed as "Transmission Fluid Cap."
So I suppose the answer is "maybe"?
ID:	126553   Click image for larger version
Last edited by bignick2015; 09-14-2016 at 06:47 AM. Reason: remove the stupid auto-hashtag link thing
post #14 of (permalink) Old 09-14-2016, 07:25 AM
Quoted: 355 Post(s)
Strange... I wonder if the 4-cylinder uses the same trans? Maybe it's a 6T50 instead of a 6T70 or something?
We'll have to have someone with a V6 and a 4 cylinder model check to see if they have a trans dipstick.
post #15 of (permalink) Old 10-09-2016, 10:23 AM
CaLefty's Avatar
I had the same issue when shifting into 3rd when turning left or trying to pass. Took my car in 3 times to the dealer. Each time they said no issue found and I codes. Just before I took it in for an an change at 47,000 miles, i was checking the air filter and noticed the air tube that goes from the air filter to the throtal boby had a tear in the flex part. After doing a quick fix by using electrical tape until can get a new one ordered. My shifting problems went away. The problem was extra air entering past the air flow sensor and the computer couldn't compensate and add fuel.
CaLefty is offline
Transmission slipping help! big_sammy610 Autocare and Maintenance 2 03-15-2016 07:11 PM
Transmission slipping when going from reverse to drive Kkowals Chevy Impala 8th Gen Discussion 3 05-21-2014 04:04 PM
Transmission Slipping!? BowTiesAndPiercings Autocare and Maintenance 3 11-03-2013 05:49 PM
Transmission Slipping!? BowTiesAndPiercings Chevy Impala 7th Gen Discussion 6 07-17-2013 07:47 AM
how do i know if a transmission is slipping? my 92 caprice has a pull on it when... Paula R Chevy Caprice 1 05-14-2008 01:20 PM
