Camshaft Actuator Solenoid (2008 LS 3.5L flex K) - Chevy Impala Forums
post #1 of (permalink) Old 09-25-2013, 04:37 PM Thread Starter
Ray2138's Avatar
Started my car this morning and out of no where , my CEL came on. I plugged up my OBDII , and it gave me a "P0010" code. Which came to be "Camshaft Position (CMP) actuator solenoid control circuit ". Im not sure exactly where this actuator is located, or how hard it would be to access and change it if possible. I have yet to find anybody else with the same problem yet with theirs. ANY ideas or input would be greatly appreciated.
Ray2138 is offline
post #2 of (permalink) Old 09-26-2013, 09:47 AM
It has come up a couple times here, but it isn't common. The actuator is located on the front of the block where the camshaft goes in. Directly under the PS pulley.
post #3 of (permalink) Old 09-26-2013, 02:06 PM Thread Starter
Ray2138's Avatar
I swear man you are a life saver!!!! I look forward to your responses on my questions. I figured out earlier today at work that the piece I was looking at was the cam actuator. I just needed the confirmation. So now it's finding the part and figuring out can I do it myself .
Ray2138 is offline
post #4 of (permalink) Old 09-26-2013, 04:00 PM
No problem, wish I could help further, but I have not had to replace one of those yet.
post #5 of (permalink) Old 09-26-2013, 10:11 PM Thread Starter
Ray2138's Avatar
It's looks fairly easy like four screws and a plug. Ill let you know how it turns out.
Ray2138 is offline
post #6 of (permalink) Old 09-27-2013, 05:56 AM Thread Starter
Ray2138's Avatar
Checking it out the morning. when I unplugged the connector, to check it and the wire is frayed. It was rubbing against the serpentine belt. So I may be just looking at a plug connector .
Ray2138 is offline
post #7 of (permalink) Old 09-27-2013, 10:21 AM
That would be much easier, and cheaper! I bet that's it.
post #8 of (permalink) Old 09-27-2013, 07:33 PM Thread Starter
Ray2138's Avatar
So I spliced the wire together and cut the light off with my obdII reader. Everything is ok ill just have to order another plug connector. ALSO if the actuator goes bad it will effect how the tranny shift . I didn't believe if but it does. it gives it that hard stiff snatch into gear as they are changing. I thought my tranny was messed up again so I took it back to the place that rebuilt it. And that's when I found out that it effects it. And I also found out my oil pressure sending unit circuit is bad or the unit it self is bad .
Ray2138 is offline
LinkBack to this Thread: http://www.impalaforums.com/8th-gen-engine-performance/410393-camshaft-actuator-solenoid-2008-ls-3-5l-flex-k.html
2008 impala problems actuator This thread Refback 05-29-2015 06:42 AM
8th Gen Engine Performance on Chevy Impala Forums | BoardReader This thread Refback 10-22-2013 09:36 PM
2008 Impala LT Flex Fuel prodigo04 Chevy Impala 8th Gen Discussion 12 02-13-2012 12:57 PM
Chevrolet : Impala LT FLEX FUEL 2008 CHEVY IMPALA LT FLEX FUEL SS WHEELS WITH ONLY 38 RSS Bot eBay Cars For Sale: Impala 0 12-18-2011 09:52 PM
Chevrolet : Impala LS Flex Fuel Chevy Flex Fuel LS OnStar Cruise 55k Miles Amber Bron RSS Bot eBay Cars For Sale: Impala 0 09-16-2011 11:00 AM
Camshaft ?????? kobiewhite 8th Gen Engine Performance 13 08-02-2011 08:32 AM
2008 Impala Driver Rear Actuator Replacement HELP! eugeneo Automotive Discussion 0 04-22-2011 11:10 AM
