need a radiator for my 06 SS advise please - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 8th Gen Discussion > 8th Gen Engine Performance
Old 07-27-2012, 11:57 AM   #1 (permalink)
bigjohn677's Avatar
Bought an 06 Chevy Impala SS about two weeks ago with just over 100K on it and yesterday it ran hot twice and cooled down, I babied it home and water was leaking out of the radiator... If it needs replacing, is there an oversized one avail. that i can put back in it? My funds are limited, I can get a great discount from the "box" part houses.... would an aftermarket one work well for me here? the tranny is shifting a little rough, but now the radiator is a bigger problem. I'm new here and really could use some advise. havent taken it anywhere yet, going to pull the codes and see what they are. The oil had just been changed, display said 98% until it ran hot.. now it says change oil.... any thoughts appreciated Thanks !!!!
bigjohn677 is offline   Reply With Quote
Old 07-27-2012, 01:51 PM   #2 (permalink)
Storm Trooper Ralf
MixedImpala04's Avatar
Take it to a radiator shop, around here you can get a new radiator installed with the coolant for 170.00 max
MixedImpala04 is offline   Reply With Quote
Old 07-27-2012, 02:03 PM   #3 (permalink)
csawyer's Avatar
I see you're from SC, are you anywhere near Charleston? I have a buddy here in town that is an amazing mechanic and I know he'd fix you up without raping you on the cost.
Sawyer
"Never drive faster than your guardian angel can fly!"
csawyer is offline   Reply With Quote
Old 07-28-2012, 01:07 AM   #4 (permalink)
bigjohn677's Avatar
found out it is the water pump gone bad. still interested in replacing the radiator if I can find a better one that came with it. that would cool the motor and tranny better.... should I replace the thermostat at the same time replacing the water pump?
thanks for your help guys!!!
Old 07-28-2012, 01:09 AM   #5 (permalink)
bigjohn677's Avatar
4 hours away from Charleston thanks for the info though....
Old 07-30-2012, 10:54 AM   #6 (permalink)
Yes, replacing the thermostat is a good idea. I thought you said the radiator was leaking? Did you just think it was, and it was really just the water pump? If it ain't broke, don't fix it. I don't know if there are oversized radiators available, but that's never really been an issue with these cars.
Old 08-19-2012, 02:19 AM   #7 (permalink)
bigjohn677's Avatar
was the water pump all along... new one cost 40.00 off of e bay... plus antifreeze paid the mech 60.00 to install... didnt flush it... they wanted 50.00 extra for a flush... just going to roll the dice.... so far everything ok......
Old 08-20-2012, 10:52 AM   #8 (permalink)
I wouldn't worry about it if the coolant looks ok, they still would do a drain and fill when changing the pump. That is usually plenty.
I need paint repair advise! wings_fan19 Autocare and Maintenance 14 06-11-2012 08:15 PM
Dial in advise needed. NTK PCM and Technical Tuning 0 03-23-2011 04:23 PM
Thinking about buying a 1996 impala ss please help need advise bobbyking88 Chevy Impala 6th Gen Discussion 13 02-06-2011 06:42 PM
i need some advise about my 2oo4 impala MEANDEAN1982 7th Gen Engine Performance 3 01-14-2009 02:01 PM
anyone gave some advise im buying either savana or express,what would be a babes_30esjm Automotive Discussion 2 09-06-2007 01:28 AM
