Currently my 08 LS 3.5L has a cold air intake (for most of the life of the car). Could this modification lead to the notorious p0455 code reading?...I'v had the "code" on and off for 3 years...I'v had 3 or 4? new gas caps- lockable and std, they always helped at 1st so i could pass N.Y.State inspection hahaa.
(Maybe this is a repost, or the idea is just crazy....either or- sorry if i wasted ur time)
I don't think so, typically its either the evap purge solenoid, or the valve. One is on the driver side top of the engine, one is by the fuel filler door. The one by the fuel filler you can remove and clean up to fix usually, the one on the motor needs replaced, but both are fairly cheap.
Thx for the post...i'll have to check it out...i have seen that in other posts...but yea just was think about the cold air intake, figured it did not relate.
What do u think of the new caprice its just for cops yet?...looks good to me...Australian car right? to bad the G8 had to die but that caprice is similar?
