knock/clicking noise in engine - Chevy Impala Forums
post #1 of (permalink) Old 03-10-2012, 08:23 PM Thread Starter
leonb's Avatar
Question knock/clicking noise in engine
I have a 2011 impala 3.5 and when i start it up hot or clold i hear a knocking type noise on the right side of the engine. i talked to a mechanic at the chevy dealership and was told this is normal, that the harmonic balancer on the front of the engine makes the noise when first started is this correct or should i seek more input from dealer car has 23,000 miles any suggestions welcome, new member as of today form Okla
leonb is offline
post #2 of (permalink) Old 03-10-2012, 11:01 PM
phileaglesfan's Avatar
Isn't the 3.5 sideways like the V8 is? They could be right. Maybe video tape it. That is also where the accessory belt parts are.
phileaglesfan is offline
post #3 of (permalink) Old 03-12-2012, 11:04 AM
6 3.5's, all over 150k miles, never heard any knocking. I would say not normal.
post #4 of (permalink) Old 03-14-2012, 06:55 PM
Welcome, Leonb! As you've seen (above), this Impala forum has a lot of knowledgeable members who give helpful feedback. I'm also available anytime via private message if you have vehicle questions or concerns you'd like me to investigate on your behalf (for example: vehicle build, warranty info, dealer info, etc.).
If the knocking continues, I suggest you take your car back to the dealer for more service. If you'd rather visit another dealership, please let me know and I'd be happy to find alternatives for you.
Best,
Katie
Chevrolet Customer Service
post #5 of (permalink) Old 03-30-2012, 02:58 PM
Pedal to the Metal
Kt.mp05's Avatar
Try running a tank of 93 Octane. After i found out that the SS need 91 or higher, i start to use it and found out i didnt here the knocking. I use to get it when it was cold or after a hard drive.
Kt.mp05 is offline
post #6 of (permalink) Old 04-01-2012, 07:14 PM
Or throw a bottle of techron in for a tank or two.
post #7 of (permalink) Old 08-07-2012, 10:33 PM
Csm2004's Avatar
Did they find a solution to you problem because I'm having the same problem but my 2011 impala has 27500 miles the Chevy techs said it was normal too and I disagree they call GM engineers they said that the noise is coming from my heat shields but it can't be because my car has been running for 30 min non stop any suggestions
Csm2004 is offline
post #8 of (permalink) Old 08-11-2012, 07:47 PM
retiredpauly's Avatar
Quoted: 75 Post(s)
Just for grins and giggles if you have access to a diagnostic stethoscope ( you can get them cheap at auto supply places ) next time you hear the noise try listening to the purge valve under the hood. It's friggen NOISY and that is where I found the "Knocking Noise" on mine. It's intermittent and I did manage to mitigate it greatly with a rubber grommet and about 15 minutes of fiddling. Apparently they are just noisy and I thought for a long time it was a bottom end noise, or stuck lifter or loose torque converter but that is what I found.
Put the probe on the valve and have a listen. THUMP THUMP THUMP THUMP
Just eliminate it as NOT the issue, but, they are friggen NOISY for sure.
P
retiredpauly is offline
LinkBack to this Thread: http://www.impalaforums.com/8th-gen-engine-performance/315609-knock-clicking-noise-in-engine.html
knock/clicking noise in engine - Chevy Impala Forums : 2011 Impala Forum This thread Refback 03-10-2012 11:46 PM
steering clicking poping-noise uphill under torque blackimpalals Chevy Impala 7th Gen Discussion 1 10-24-2010 11:56 AM
Clicking noise while turning right BUCKEYE Automotive Discussion 6 07-13-2010 06:58 AM
impala clicking noise by alternator stanthemanimpala Chevy Impala 7th Gen Discussion 7 04-01-2010 10:53 AM
My 03 Impala is in the shop for a clicking noise that seems to be coming K.M. Mechanical and Electrical Problems 0 09-03-2007 07:23 PM
I have an 03 Impala with 77 thousand miles. There is a clicking noise coming... K.M. Mechanical and Electrical Problems 1 09-03-2007 06:52 PM
