Throttle Position Sensor - Chevy Impala Forums
post #1 of (permalink) Old 11-19-2009, 12:35 PM Thread Starter
csherrill's Avatar
I have a 2007 Impala SS. Where is the Throttle Position Sensor located? I need to replace this and need to know where it is located. I am getting a Check Engine Light Code P0121.
csherrill is offline
post #2 of (permalink) Old 11-18-2013, 06:21 PM
Maximus's Avatar
Me 2
I have the same thing going on with a 2008. Anyone with this wisdom out there please post.
Maximus is offline
post #3 of (permalink) Old 11-18-2013, 06:25 PM
auntjemima's Avatar
Open the hood and locate the throttle cable.. follow it to the twisty thingy... thats your TPS.
auntjemima is offline
post #4 of (permalink) Old 11-18-2013, 08:47 PM
SuperDave's Avatar
Send a message via AIM to SuperDave
There should be one on the pedal as well since it is DBW.
2001 Impala 9c1: SLP CAI: L67 coils:PRJ wires:ZZP volt booster:Fuel pump rewire:Trans cooler:HD diff/axle:Home made Shift kitrilled 180* Tstat:Flipped MM's:GTP dual exhaust:Aero force scan gauge:Whelen 90watt Strobes front/back wig wag reverse lights:Whelen air horn:Wig wag headlights.
SuperDave is offline
post #5 of (permalink) Old 11-18-2013, 08:49 PM
auntjemima's Avatar
a 2007 is dbw?
post #6 of (permalink) Old 11-18-2013, 08:57 PM
SuperDave's Avatar
DBW "Drive By Wire" yes, not DBC "Drive By Cable".
post #7 of (permalink) Old 11-18-2013, 09:37 PM
Quoted: 350 Post(s)
Yeah, DBW has been around for some time now. Even my 2005 Buick LaCrosse is DBW... To be perfectly honest, I kind of prefer the older cable-based throttles though! Sometimes, the DBW can make the throttle seem "disconnected" - maybe because it is! :-)
post #8 of (permalink) Old 11-19-2013, 05:44 PM
Bart77's Avatar
Quoted: 15 Post(s)
A P0121 is set when The ECM detects that the airflow rate is greater than the calculated airflow for greater than 0.2 second.
You can try to clean the throttle body and then do a idle learn reset (you will need a Tech2 for this) and see if the code comes back. Or replace the throttle body and do a Idle learn reset (with a Tech2).
For those who are wondering the TPS is located inside that big black plastic cover on the throttle body that the electrical connector plugs into. For the correlation code, DTC P2135, this piece is replaceable separately from the throttle body.
Bart77 is offline
The Following User Says Thank You to Bart77 For This Useful Post:
sheila (11-19-2013)
LinkBack to this Thread: http://www.impalaforums.com/8th-gen-engine-performance/241401-throttle-position-sensor.html
2008 chevy impala throttle position sensor location - Web Search Results This thread Refback 04-28-2014 07:33 AM
Throttle Position Sensor Chevy Impala This thread Refback 01-22-2014 03:45 PM
8th Gen Engine Performance on Chevy Impala Forums | BoardReader This thread Refback 11-28-2013 11:21 PM
What is P0121 CHEVY IMPALA? This thread Refback 10-27-2013 06:14 PM
Impala Throttle Position Sensor Location This thread Refback 08-24-2013 08:55 PM
2002 Chevrolet Impala - Intermittent won't crank with key in start position.? Zack W Chevy Impala Discussion 8 08-08-2011 07:10 PM
63 2door - rear quater badge position [ UNEASY ] Restoration Forum 4 01-04-2010 11:59 PM
Throttle Position Sensor RATLIFFD 6th Gen Engine Performance 2 08-14-2009 05:25 PM
could the Throttle Position Sensor give my 01 impala a slow take off and... ronda6729 Chevy Impala Discussion 1 07-27-2008 06:03 PM
How to reset the tire position on a 2007 chevrolet Impala? Joe M Wheels and Tires 3 12-14-2007 05:30 PM
