Throttle Response - Chevy Impala Forums
post #1 of (permalink) Old 07-14-2009, 10:11 AM Thread Starter
FreeLTZ's Avatar
Throttle Response
Hello all, first post here. Haven't done forums in a long time so excuse my etiquette if I screw up.
I was smart enough to run a search and didn't see anything that jumped out at me but I'm sure one of the board gurus (all boards have them) will be able to point me to the thread if it exists.
OK, so here's the problem..............
2008 Impala LTZ 3.9 ordered from the factory and received June '08. (and for those curious about my screen name, yes I got it FREE! Actually my wife won it in a contest at work....cool huh!? )
Anyway, back to the issue at hand....
We love the car and have had little to no complaints about it in this first year. However recently I have discovered that I believe it is trying to kill me. How? By way of a lagging throttle response. I never noticed it until after we took it in for the A/C recall and an oil change. Even then it wasn't immediately noticed. However as time goes by I am having more and more issues with it. I step on the gas and it seems to take 1-2 seconds before anything happens. I don't drive like too much of a madman so it's usually not an issue but more than once I've found myself needing to yield and then hit it to get in traffic in the slot, I hit the gas and......nothing. Then it spools up and takes off like a bat outta hell.
I've read somewhere that it is because it's electronic instead of having a wire to the carb and that it adapts over time to your particular driving habits. I've also read that there is a way to reset it by pressing the pedal down slowly and releasing it slowly with the ignition on and motor off.
My question here is.......
1) Has anyone else had this issue?
2) Does the above method actually work?
3) If so what are the correct instructions?
4) If not, any suggestions to correct it that do work?
As I said I don't drive like a madman too much but when I hit the gas on a $30K car I expect it to respond at least as good as my 10yr old van which the LTZ just doesn't.
FreeLTZ is offline
post #2 of (permalink) Old 07-18-2009, 06:52 AM Thread Starter
FreeLTZ's Avatar
Wow, 38 views and nobody else has had this problem or one similar? :confused:
Guess I'll take it back to the dealer and have them check it.
FreeLTZ is offline
post #3 of (permalink) Old 07-18-2009, 09:48 AM
Moderator
04DetroitLS's Avatar
Originally Posted by FreeLTZ View Post
I've read somewhere that it is because it's electronic instead of having a wire to the carb and that it adapts over time to your particular driving habits. I've also read that there is a way to reset it by pressing the pedal down slowly and releasing it slowly with the ignition on and motor off. .
the PCM is a "learning" pcm so yes it does "adapt" to your driving habits. Not sure on the reset proceedure (7th guy) but you could always try to disconnect your battery for ~1/2hr , reconnect take it around the bolck a few times stomping on it from a dead stop and see it that works
04DetroitLS is offline
post #4 of (permalink) Old 07-20-2009, 10:33 AM
Manoogia86's Avatar
Once in a while I will notice something similar, but the lag is nowhere near a full 1-2 seconds. It is more like a fraction of a second. Also, it doesnt happen when easing onto the gas, but when taking my foot off the gas, the throttle will (very rarely) take a fraction of a second to respond.
If your throttle response is actually detrimental to the way you are driving and potentially hazard causing, you should probably get it looked at and corrected. Regardless of the way the system adapts to your driving habits, the throttle response should be accurate in terms of foot on the gas/foot off the gas.
Manoogia86 is offline
post #5 of (permalink) Old 07-18-2010, 07:10 PM
Lynn63's Avatar
Sorry to resurrect an old thread, but our 09 LTZ 3.9L does exactly the same thing and the dealer keeps telling us they can't find anything wrong. It also gets 24-25mpg on the highway which is worse than any car we've had in the last 10 years. Our 2000 SSEi was always in the 30mpg range on the highway and also our 2004 Grand Prix and our 2006 F**d 500 Limited. There has to be some correlation between the hesitation and throttle position. It seems like we have to press way too far on the accelerator to get the car moving and if I'm not mistaken, the higher the throttle position the higher the demands on the injectors.
Anyone else had any issues and hopefully a possible fix? Our dealer continues to stonewall us.
Thanks,
Lynn
Lynn63 is offline
post #6 of (permalink) Old 07-18-2010, 08:06 PM
Z71
Z71's Avatar
Quoted: 5 Post(s)
You are complaining about 24 MPG? I cannot get past 21 MPG with my '09 LTZ so far. I tend to drive rather fast on interstates, but nothing crazy - about 80 MPH and accelerate normally. The car has good throttle response, no complaints at all about that.
I would recommend a few things to those complaining about throttle response. Use some Chevron Techron injector cleaner in you gas tank, mix one 12 Oz bottle with about 8 gallons of gas and run until the tank is almost empty. Do another treatment if you do not notice immediate improvement. This stuff really works.
Also, try different brand of gas. I have found that some of my vehicles run better on certain brands of gas. Could be different additives.
Z71 is offline
post #7 of (permalink) Old 08-02-2010, 09:42 AM
Kingmanbc's Avatar
If you buy cheap gas then that can cause your problem, I buy 93 everytime...
ss (super sport)
Kingmanbc is offline
post #8 of (permalink) Old 09-02-2014, 10:55 AM
wolken's Avatar
every get resolution on this thread?
wolken is offline
post #9 of (permalink) Old 12-08-2016, 05:05 AM
DDM2010's Avatar
Have exactly the same problem with my 2010 3.9. Have not found a fix as yet. It's a flex fuel engine and I've been told that is part of the response problem.
DDM2010 is offline
post #10 of (permalink) Old 12-08-2016, 05:53 AM
Quoted: 317 Post(s)
I've never heard of flex-fuel engines running any differently than gas-only engines. It's the exact same engine, just with a ethanol sensor and maybe some hoses made of different materials in order to handle the ethanol better. So a flex-fuel engine and a gas-only engine will run exactly the same when both are running regular gas....
jtrosky is online now
post #11 of (permalink) Old 12-08-2016, 06:06 AM
DDM2010's Avatar
My 2010 3.9 fuel flex was a Texas police car. It has 52,000 miles. I recently had a 2010 impala 3.5 loner from a Chevy dealer and was surprised to find it had much better throttle response than mine. It also had 191,000 miles and ran like a rabbit off the line compared to my 3.9 turtle.
DDM2010 is offline
post #12 of (permalink) Old 12-08-2016, 06:32 AM
Quoted: 317 Post(s)
That may be, but it's obviously a different engine (3.5l vs 3.9l) - and I'm sure that they are tuned differently from the factory (especially since yours probably has the police tune). Could also be that something isn't just right with yours. But my point is that just being a flex-fuel engine has nothing to do with it.
I've personally never owned a 3.5l or 3.9l Impala, so I honestly don't know which one is normally quicker "off the line". You would think that the 3.9l would be a little quicker though - especially with the police tune.
I think some other members have owned both though - would be interesting to hear if the 3.5l is normally quicker "off the line" than the 3.9l.
Anyone?
post #13 of (permalink) Old 12-08-2016, 07:38 AM
Quoted: 61 Post(s)
i have a 3.5 2010 impala and have had a 3.9 loaner buick lacross before. the 3.9 pulls harder off the line and can spin the tires decently. i also know by the mileage the car received that the gears were shorter as well over an hour drive of 55-80mph. the fact your car was a police car makes me wonder if the gearing wasn't changed to a taller set in order to get better mileage/higher top end out of it when it was ordered.
Joes74challenger is offline
post #14 of (permalink) Old 12-14-2016, 01:31 PM
Mjollnir's Avatar
Ive had the same problem for years. Replaced MAP sensor, cleaned the HELL out of the throttle body, (it was really gunked up) and replaced the gas pedal (had a bad circuit "A"). Runs without hesitation now.
Mjollnir is offline
slow throttle tip-in, '08 3.5 flex-fuel N8N 8th Gen Drivetrain 0 04-07-2009 07:09 PM
Throttle body spacer? 02impala 7th Gen Engine Performance 8 01-05-2009 01:55 PM
Throttle Body Spacer impala04ss Chevy Impala Discussion 4 10-16-2008 04:35 AM
Throttle Pressure Rod dogman780 1st - 5th Gen Drivetrain 4 09-08-2008 08:24 AM
Throttle body+Air foil seth7796 Chevy Impala Discussion 1 04-15-2008 01:37 PM
