Strange p0171 and p0174 codes - Chevy Impala Forums
post #1 of (permalink) Old 05-31-2017, 05:05 AM Thread Starter
eray's Avatar
2012 LTZ 3.6 Both codes have been intermittent since 80,00 miles. Dealer replaced gas cap and originally helped. Has never failed inspection and runs great. Now with 140,000 miles light is always on except when completely full of gas. Comes back on after using about 1/8 tank and stays on till next fill up. Checked all hoses and cleaned maf sensor , changed purge canister. Is there a vent or something that could be wrong with the filler neck ? Baffled!!
eray is offline
post #2 of (permalink) Old 05-31-2017, 07:33 AM
Quoted: 41 Post(s)
Really need to look at short and long term fuel trims. If trims are high positive at idle and try to normalize at ~2500rpm, indicates a vacuum leak. If trims are high positive at idle and go even higher at ~2500rpm, indicates a fuel system/delivery problem.
sheila is online now
post #3 of (permalink) Old 05-31-2017, 12:47 PM Thread Starter
eray's Avatar
I can't give up the car right now long enough to get to a shop that can run a fuel trim analysis. I did notice that the new vapor purge solenoid starts clicking continuously about 10 seconds after start up.
eray is offline
post #4 of (permalink) Old 05-31-2017, 12:49 PM
Quoted: 342 Post(s)
That does not sound normal at all... Maybe you got a bad part - it happens. Or there is something else causing it to behave like that...
jtrosky is online now
post #5 of (permalink) Old 05-31-2017, 07:46 PM
Quoted: 41 Post(s)
Got a friend with a scan tool that'll read fuel trims? I think most parts stores will just read your lean codes. Did you swap out the evap. emissions component underhood or at the drivers lr?
post #6 of (permalink) Old 06-01-2017, 06:31 PM Thread Starter
eray's Avatar
Switched out the vapor purge solenoid under the hood, the new one clicked all the time . This evening , I put the old one back on and filled the car up with gas, the old one does not click all the time and the light is still on. I am trying to think if someone I know has the fuel trim program on their scanner, my two do not. This whole thing is so baffling because the engine runs perfect. May end up taking it back to the dealer, the first time we mentioned it may be a "real problem" their first response was , we really hate it when this happens to a car this new but still runs good. Could it possibly be the upper intake manifold gasket, does this cause this kind of issue?
eray is offline
post #7 of (permalink) Old 06-01-2017, 06:59 PM
Quoted: 41 Post(s)
^ Uim gasket is possible but doubtful on a '12. If it's not sealing, it'd be a vacuum leak like a faulty vac. hose. Has the uim ever been removed to your knowledge? Can you return the clicking underhood purge valve solenoid for another? May check/suspect the evap. component in the lr wheelwell.
post #8 of (permalink) Old 06-01-2017, 07:58 PM
Bill58's Avatar
Quoted: 8 Post(s)
Pretty sure the fuel level needs to be above 15% and below 85% to run evaporative emissions monitor, EVAP. Also a open purge solenoid can cause a lean condition if its open without the ecm commanding it to open, itís basically a vacuum leak. You need to find out if and/or why the purge solenoid is turning on.
Bill58 is offline
post #9 of (permalink) Old 06-02-2017, 06:07 PM Thread Starter
eray's Avatar
What component is under the left rear wheel well?
eray is offline
post #10 of (permalink) Old 06-02-2017, 06:12 PM
Bill58's Avatar
Quoted: 8 Post(s)
Vapor Canister Vent Valve / Solenoid
Bill58 is offline
P0171 mcar585 Automotive Discussion 0 08-16-2016 02:59 AM
P0171 mcar585 Automotive Discussion 0 08-15-2016 06:47 PM
P0171 mcar585 Automotive Discussion 0 08-15-2016 05:02 PM
P0171 mcar585 Automotive Discussion 0 08-15-2016 04:24 PM
Please help me with p0171 !! jgbride Chevy Impala 7th Gen Discussion 7 04-01-2016 07:07 PM
