Service Traction Control - Page 3 - Chevy Impala Forums
post #31 of (permalink) Old 01-24-2012, 11:15 PM
Guest's Avatar
Quoted: Post(s)
thass crazy to think a mouse can fit under an engine cover....i mean the space between the engine and the cover is miniscule
post #32 of (permalink) Old 01-25-2012, 10:24 AM
Rodents can squeeze themselves into places that boggle the mind, they actually have flexible skeletons. They go to places like that for the warmth.
post #33 of (permalink) Old 01-27-2012, 10:10 PM
jimmyj923's Avatar
My 2009 Impala intermittently displayed "Service Traction Control". Took it to Chevy dealership, $85 to read codes, non set. The next time the message appeared I made sure I turned off the ignition to ensure code was stored. Had a friend with access to a Tech 2 and read out code C0040, RF Wheel Speed Circuit Malfunction. Replaced RF hub with no help. Then started playing with harness with ignition on. Every once in a while the car chimed indicating traction message. Finally narrowed it down to an area ~four inches from connector. When I squeezed the hard shield the problem occurred. When I released it went away. When I pulled the wire out of the hard shield I saw two serious indentations. My neighbor suggested they might be where they clamped the wiring harness when they made it. When I opened the insulation covering the two wires there was tape around the two wires only at this point making me believe my neighbor. After playing with the two wires, bending and pulling I finally saw the insulation color slightly change on one of the wires. I pulled harder and the insulation broke. I assume the wire had been broke and the cold contracted the wire causing intermittent problems. Soldered the wires back together but message continued. At my wits end put tire back on car and started driving to dealership. Got to first stop sign, looked down and message was gone. Must have taken wheel motion to clear DTC. Believe problem solved.
jimmyj923 is offline
post #34 of (permalink) Old 01-27-2012, 10:14 PM
Guest's Avatar
Quoted: Post(s)
I kno they can squeeze into tiny places but that is crazy
post #35 of (permalink) Old 10-13-2013, 09:59 PM
ChrisImpalaSS's Avatar
Originally Posted by SPARTAN sui View Post
Hey guys, here's the update.
I brought my car in to the dealership, as I said so in an earlier post. They did their work, it took awhile for them to get a chance to look at it. After a few hours, he called me and said it was a fouled spark plug, cylinder 3. It was throwing the traction control error because it was disabling it due to the check engine light, apparently? Seems odd, but nonetheless, the issue has been resolved and I'm happy! Runs great and now idles properly. No more chugging down sound.
I did mention to him I'm currently undergoing an oil consumption test at another dealer. Luckily for me, he also own an Impala SS, so he had a TSB in his desk about oil consumption with the LS4. This is a brand new one released on November 22nd, 2011. Here's the number if anyone is interested 11-06-01-007
I'm going to go back to the dealership near my house that's doing the test and try to get this taking care of, if not, he mentioned that they could take care of my car if my dealership won't. I like dealing with people that actually care!
Think I'm having this same trouble, 2007 SS bought new just turned 50,008 miles today. Noticed a rough idle while the car was in gear at a stop two days ago, Then today service engine light came on and about five minutes after that service traction control message and TC light came on. Funny thing too I did notice a couple pieces of acorn on the block when I was under the hood. Called Onstar had them run a diagnostic check and they told me there is a misfire in one of the cylinders, Sunday night here so going to call the dealership in the morning see if they can get it in. My SS uses oil I've had it in to them before for it, I use Mobil 1 and just try and stay on top of it. I'm going to mention that service bulletin to them. Gotta love this forum.
ChrisImpalaSS is offline
post #36 of (permalink) Old 02-20-2015, 05:50 AM
islandteddy's Avatar
Single numbers in temperature. 2009 Impala started car in morning and TC light came on with message to service TC. Car idle for a few then died. Could not restart car. Nothing.....
islandteddy is offline
post #37 of (permalink) Old 02-20-2015, 06:55 AM
Quoted: 260 Post(s)
I wonder if it could be a low/bad battery? I know that older cars would run without a battery after being started, but I *think* that newer cars will die without a battery. Although, you'd think that if it was a battery issue, that the car wouldn't have even started to begin with...
Just trying to think what the severe cold may be playing havoc with - usually, it's batteries.
post #38 of (permalink) Old 02-20-2015, 03:18 PM
pwd0502's Avatar
I had a similar issue and turned out to be moisture inside wiring harness connector to wheel speed sensors
pwd0502 is offline
The Following User Says Thank You to pwd0502 For This Useful Post:
Julie (04-03-2015)
post #39 of (permalink) Old 04-03-2015, 05:17 PM
Julie's Avatar
Is this an area of the car that i can get to myself? Or is reccomended that i take it to my mechanic?
Julie is offline
post #40 of (permalink) Old 05-15-2015, 10:38 AM
miinan's Avatar
How much did that cost you? I've had that problem for a while and it's an annoyance.
miinan is offline
post #41 of (permalink) Old 06-29-2015, 07:00 AM
08087's Avatar
I have the same problem. The TC message and a ABS came on twice. I hear a noise from the left front when backing out of the driveway and turning the wheel. The TC off light comes on and goes back off. I have had an Impala (1963 SS) as my first hand me down car. A 2002, a 2008 and now this 2013. I am thinking of getting rid of it. From what I have read, the hub goes bad and it is an out of pocket expense for me since I just hit the magic 40,000 mile marker.
08087 is offline
post #42 of (permalink) Old 07-03-2015, 02:55 PM
08087's Avatar
Just a quick update. I took my certified impala to the dealership (Bennett Chevrolet in Egg Harbor, NJ) that has been doing the free oil changes, etc. This time the oil change and rotation was 39.95 and I told the service director about the warning light and how the "off" indicator comes on briefly when I back out of the driveway and turn the wheel. He had the mechanic check it out and fix the same day. They replaced the hub and then the wiring harness - free. No charge. I love this chevy dealer. But, since the car has 41,000 miles I sold it and purchased something newer. I just wish I could have found my next car on their lot.
08087 is offline
LinkBack to this Thread: http://www.impalaforums.com/8th-gen-drivetrain/304462-service-traction-control.html
Service Traction Control - Chevy Impala Forums This thread Refback 02-21-2017 02:50 PM
Service Traction Control - Page 3 - Chevy Impala Forums This thread Refback 03-02-2015 05:38 PM
Service Traction Control Page 3 Chevy Impala Forums - Infoter.blg.lt This thread Refback 01-29-2015 12:59 PM
service traction control impala - forums post summary | BoardReader This thread Refback 12-31-2013 02:12 PM
2006 Impala - Service Traction Control jhager Autocare and Maintenance 5 02-25-2011 08:04 AM
Service ABS and Traction Control warnings! AlfredoSmith Chevy Impala 8th Gen Discussion 12 09-09-2010 06:01 AM
Service Traction Control System indyimpalass 7th Gen Drivetrain 16 05-12-2010 06:47 AM
Service Traction Control problem AKvsAR Chevy Impala 7th Gen Discussion 26 04-06-2010 07:53 AM
Traction control service light cfjames11 Autocare and Maintenance 3 12-07-2008 01:38 PM
