Trying to diagnose transmission issue - Chevy Impala Forums
post #1 of (permalink) Old 05-19-2010, 07:19 AM Thread Starter
AlfredoSmith's Avatar
Car is 07SS. Once in a while, when slowing down after acceleration, the car jerks and shutters upon re-accel. Its most prominent going uphill. The issue is very hard to replicate since I removed the tune (superchips). I have about a year left on my powertrain warranty and wanted to try to get the issue looked at, but again I cannot seem to replicate it.
Could this be a component of the transmission that I could replace myself for low cost?
Thanks in advance guys (and gals (G.B.A.))
AlfredoSmith is offline
post #2 of (permalink) Old 05-19-2010, 08:17 AM
Moderator
wanderson75's Avatar
Triple Edge Performance has some good info on common failure points in the 4T65E transmission. You can check it out here: http://www.tripleedgeperformance.com..._Problems.html
That might give you a good starting point.
How many miles are on the trans?
–adjective
wanderson75 is offline
post #3 of (permalink) Old 05-19-2010, 08:19 AM
94ss68c10's Avatar
Send a message via MSN to 94ss68c10
its usually the torque convertors that fail with the LS4 cars
1997 Camaro - Ported, Polished, Milled, Cammed. + way more
2006 Grand Prix GXP- 5.3 LS4,HP Tuned by Shady Milkman. Magnaflow, 13.9@98mph
1994 Impala SS - 98k miles SOLD
94ss68c10 is offline
post #4 of (permalink) Old 05-19-2010, 08:25 AM Thread Starter
61,000 on it... i bought it abt 12 months ago with 33,000 on it and the transmission was pristine. Now shes a PIG
post #5 of (permalink) Old 05-22-2010, 08:56 AM
rkvette's Avatar
just take it to gm dealer !! no charge to fix a 2007, 100,000 mile deal !! may not need tranny exchaged ,? they will tell you whats up ,no guess work and no charge to fix,cant beat that.. good luck-rkvette
rkvette is offline
post #6 of (permalink) Old 06-02-2010, 11:11 AM
bad03xtreme's Avatar
My Mom's 07' SS has the same issues the tranny slips and slams into gear at take off. I think the trannys were not made to handle the power the engine produces. Every trip to the dealer is just some other exuse about how that is "normal"...
bad03xtreme is offline
post #7 of (permalink) Old 06-03-2010, 02:42 PM
rkvette's Avatar
just keep driving it , sooner or later ,tranny will slip/rev, enough to be changed/ gm rebuilt,but get 100,000 deal on the tranny !! rkvette
rkvette is offline
post #8 of (permalink) Old 06-04-2010, 10:57 AM Thread Starter
Id prefer to have the issue fixed before I am left stranded on the highway halfway between NJ and VA. I hear a lot of people say they experience the same issue, but have not heard one idea as to what could be causing the problem.
post #9 of (permalink) Old 06-13-2010, 03:26 PM
rkvette's Avatar
alfredosmith- causing the the problem is bad trannys,from gm..!!.espically on the 2006 cars..daughter 2006 monte carlo ss v8, was sliping/banking into gear like every body said ,and keep getting a little worst daily, she traveled about 150 miless round trip to her job in nj, 5 days a week.. when gm dealer pulled down the pan was all kind of junk in there.. this happened at about 40,000 miles out of warranty for an 2006..we had some dicussions with dealer, and they knew that was a problem, with these trannys ! split the bill with us.. bill was $3,500 for rebuilt gm tranny,we paid $1750 , total !! and also gave her a new loaner car ,while tied up.not a ss or anything, but was wheels...monte has 100,000 miles on and great car never back to dealer since., the tranny still has 40,000 miles on warranty.. of course if its a 2007 all this is free, for the first 100,000 miles..rkvette
rkvette is offline
post #10 of (permalink) Old 06-13-2010, 05:37 PM
mrant212's Avatar
My 08 SS is starting to slip a bit as well with 76k miles on it. Dealer said I should just do a tranny flush... I would rather get a new tranny!! Cant see that a tranny flush would help this matter!
mrant212 is offline
post #11 of (permalink) Old 06-13-2010, 06:38 PM
rkvette's Avatar
i guess if your gm dealer wants to do that n/c ,its ok .. dealer may think with high miles , may/help take care of the problem ? if does not solve it you tried dealer ,solution... about 10 years ago with a company car mopar/chrysler, dealer did that slipped the same and leaked bad.. soon after tranny had to be replaced.. you are luckly have a 2008 impala, covered for 100,000 warranty ! good luck and stick to it, to get the results.. rkvette
rkvette is offline
post #12 of (permalink) Old 06-27-2010, 10:56 AM
dro1dro1's Avatar
feels like shift shock for me in 1rst throught 3rd then during mild acceleration to about 40 then easy the throttle but not taking my fooot off the throtle the gently trying to accelerate again trans slips and revs to 4 grand then slowly back to 2 grand then catchs but not jerky just like annoying could it be the clutch
2006 impala ss
black on black on black
2 12's diamonds comps
quantum audio 1800 watt amp
wit stock head unit
dro1dro1 is offline
post #13 of (permalink) Old 07-21-2010, 12:36 PM Thread Starter
Got my rebuild from GM, also changed the front motor mount. Problem has gone away for the most part. I think the slamming into first issue was caused by the motor mount. The other issue was a "burnt #2 clutch" according to the lead tech.
post #14 of (permalink) Old 07-21-2010, 02:24 PM
rkvette's Avatar
MERRY CHRISTMAS !! told you just hang in there, sooner or later gm will replace/rebuild tranny.. its their fault, not your's . rkvette
rkvette is offline
Another transmission issue. carlton_fritz 8th Gen Drivetrain 10 05-19-2010 06:40 AM
Transmission linkage issue? AlfredoSmith Chevy Impala 8th Gen Discussion 4 02-25-2010 02:10 PM
Oil issue PackmanT Chevy Caprice 7 05-29-2009 03:54 PM
Transmission issue Fordtruckfreeek Chevy Caprice 1 05-16-2009 09:09 AM
Transmission issue bigcat24 Chevy Impala Discussion 9 03-02-2009 09:39 AM
