| 8th Gen Drivetrain Transmissions, clutches, and axles. |
Another transmission issue.
I'm new and was referred to this site to find info. 2009 SS. When pulling out from a dead stop, if I get on it a little to get into traffic or ahead of oncoming traffic, sometimes the car stays in 1st and won't shift. I let off the gas some to coax it into shifting and it drops out of gear. I know this due to the RPMs going up when I get back on the gas and not accelerating. I then let off the gas for a couple seconds and then the car shifts into 2nd. If it does that while I am trying to pull into traffic, I may end up smashed. If I get on it hard to pull out, it goes fine until it hits what appears to be a rev limiter and then I have nothing like the governor is engaged. It isn't smooth either. I believe the no shifting part is only when the car is cold. However, it did do this one time when I was trying to pass someone. Do not recall if the car was warmed up at that time. Can anyone help?
#2 (permalink) | |
Take your car straight to the dealership. Sounds like you've got a bad tranny.
__________________ ![]() Quote:
#3 (permalink) |
You might have some tranny slip, but take it in just in case.
Now if you pull out hard with the T/C(traction control) on then yes its going to kick and buck when you spin the tires. That lets you know it doing its job. Also if you're trying to make a left/right turn and power into it, it will also kick "bog" down. Also about when you were passing someone and it felt like it didn't shift: If you were out of the power band then it won't respond with a hard downshift and a burst of power.
#4 (permalink) | |
#5 (permalink) | |
#6 (permalink) |
So the dealer tells me that it's normal for the transmission to drop out of gear when it's cold to protect the transmission.
#7 (permalink) |
Get it in writing with the Service persons name, so if you tranny messes up on you they are liable.
#8 (permalink) | |
Personally, I'd take it to another dealer.
#9 (permalink) | |
#10 (permalink) |
That is definitely not normal. My '09 LTZ shifts up crisply and downshifts without any hesitation even with slight throttle input.
I have test driven cars like 2006 Crown Victoria with the sport package and the car was reluctant to downshift when the gas pedal was pressed. It hesitated for about a second before downshifting. I found this unacceptable so I did not buy the car. But not upshifting from the first gear? That seems ridiculous. You may have a faulty pressure solenoid or something in that transmission. Maybe it is acting up intermittently.
#11 (permalink) |
My 09 SS does not act at all like this. I had a truck, 07 Escalade that had a similar issue - the dealer reprogrammed the ECU with an update and it was all fixed. Have not heard of any TSBs though with the 09 SS.
__________________ 09 Impala SS; 01 Seville SLS |
| New stalling issue | Project 64 Impala Wagon | 1st - 5th Gen Engine Performance | 4 | 07-13-2009 02:53 AM |
| Oil issue | PackmanT | Chevy Caprice | 7 | 05-29-2009 02:54 PM |
| Transmission issue | Fordtruckfreeek | Chevy Caprice | 1 | 05-16-2009 08:09 AM |
| Transmission issue | bigcat24 | Chevy Impala Discussion | 9 | 03-02-2009 08:39 AM |
| Shiffer issue | RANDY HEINTZ | 7th Gen Drivetrain | 0 | 06-26-2008 07:32 AM |
