Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 7th Gen Discussion > 7th Gen Suspension
7th Gen Suspension Springs, shocks, and brakes.
Old 05-25-2009, 11:32 PM   #1 (permalink)
andrew805's Avatar
Question My 05 makes a noise when i take off or when i brake
My car is making a knocking noise when i take off from a red or when i press on the brake and i noticed when i make a turn it knocks.
Anyone have any idea what it is and how to fix it. Please its starting to annoy me
andrew805 is offline
Sponsored links
Old 05-26-2009, 03:22 PM   #2 (permalink)
Manoogia86's Avatar
My first thoughts are motor mount or axle...
Manoogia86 is offline
Old 05-26-2009, 05:21 PM   #3 (permalink)
wedebrook's Avatar
Intermediate Steering Shaft.
I'm Old Gregg.
wedebrook is offline
Old 05-31-2009, 11:28 AM   #4 (permalink)
PeterMeridingo76's Avatar
hey check your control arm bushings or your control arm , i thought it was my iss but apparently i had a bad control arm , now im stuck driving my family wagon until i get my new control arms , mines are cracked because i didnt realize the problem
http://www.cardomain.com/ride/677594
1988 Chevy Monte Carlo
2000 Chevy Impala 9c1
PeterMeridingo76 is offline
Old 10-07-2009, 08:29 PM   #5 (permalink)
pdqwrx's Avatar
I have a similar issue with my 04...When taking off it almost feels like the springs are unloading and popping and I can feel it through the wheel, especially when I am in a turn. Definately seems to be related to the front end getting light. I am thinking it might be a bad strut top bearing? I'v got 80K on the clock so I am going to buy new struts anyway so I will replace the bearings as well.
My steering is all A OK according to both my and my mechanic's inspection.
Any other ideas....
pdqwrx is offline
Old 10-08-2009, 01:44 AM   #6 (permalink)
also you can check yur cradle bolts , this usually happens when they are loose , tighten them to specs i dont remember what the specs where , diagnol braces, also check your control arm bushings,
vB code is On
Transmission makes knocking noise when it shifts back to first in my 93 Firebird formula93_350 Automotive Discussion 0 06-21-2008 05:57 AM
I have a 2002 Impala that makes a metalic ringing noise on acceleration.? Steven H Chevy Impala Discussion 0 05-02-2008 09:19 AM
94 Camaro power steering issue, replaced pump, and still makes noise? Hyd Automotive Discussion 1 03-06-2008 01:38 PM
when i pull my emergency brake it doesnt stay up and you can hear some noise Erric C Automotive Discussion 2 09-08-2007 11:18 AM
Brake lights go out when headlights are turned on and brake is applied.? THOMAS C Automotive Discussion 5 09-04-2007 02:07 AM
Sitemap Index - Archive
