Lowering car - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 7th Gen Discussion > 7th Gen Suspension
7th Gen Suspension Springs, shocks, and brakes.
Old 12-11-2007, 04:34 AM   #1 (permalink)
DSSTRBD's Avatar
Lowering car
Anyone lower their newer impala? What springs did you use? How many inches was the drop and was a camber kit installed?
04 INDY Impala SS
Stock
95 DCM SS
383 Ai topend
Level 4 trans w/ Edge 3700
443 RWHP NA
545 RWHP 100 shot
ISSCA # 2390
DSSTRBD is offline   Reply With Quote
Old 03-11-2008, 05:26 PM   #2 (permalink)
dagoose502's Avatar
Before I decided to air ride my impala I was looking into buying a set of lowering springs from neuspeed. I believe you can get up to a 2" drop out of them. That just wasn't low enough for me though As far as the camber kit, I wouldn't think you would need it. The camber in the rear even with the air ride doesn't wear the tires bad at all.
dagoose502 is offline   Reply With Quote
Old 04-21-2008, 07:36 PM   #3 (permalink)
65impSS's Avatar
Send a message via AIM to 65impSS
I went with Eibach and it lowered it about 1.4"front 1.6"rear and they didnt make the ride real stiff, look in my garage and you can see a pic of it, and i did not have to install the camer kit
Jon
04 SS
65 SS convt 396
65impSS is offline   Reply With Quote
Old 11-16-2008, 02:50 PM   #4 (permalink)
Lingenfelter's Avatar
SS model springs will give you the smallest drop possible. Eibach also makes springs, as do a few other companies.
How much drop are you looking for?
Top 10 poster at NAIOA.
Top 10 poster at NewImpala.
Lingenfelter is offline   Reply With Quote
Old 12-16-2008, 07:41 PM   #5 (permalink)
OhhImpala's Avatar
I have heard only good things about the eibach and kyb strut/shock combo with w-bodies. I plan on installing the eibach and kyb combo on my impala. From my monte carlo club, I found this was a very popular choice because they are good products.
2005 Impala SS
OhhImpala is offline   Reply With Quote
Old 12-17-2008, 05:46 AM   #6 (permalink)
Moderator
04DetroitLS's Avatar
SSC and Eibach are the 2 most popular, SSC doesnt lower as much as the Eibach, and from what Ive read rides nicer ( when both equip't w/ AGXs) check each nfg's website, they say how much it drops the car
04DetroitLS is offline   Reply With Quote
Old 12-26-2008, 08:10 AM   #7 (permalink)
OhhImpala's Avatar
I am getting the KYB AGX struts for my 2005 impala. Do I need to get new strut mounts or will the stock mounts be suffice?
2005 Impala SS
Old 12-30-2008, 10:48 AM   #8 (permalink)
Thatisugly's Avatar
Also, i was at my local AutoZone, and i saw a kit for lowering this generation of impala for like 20$, i didnt get to look at it much because i was in a rush, but it looked pretty legit.
It said it will lower or raise the car up to 4 inches either direction. Im not sure if its reliable or a great deal, so dont hold me accountable lol
Thatisugly is offline   Reply With Quote
Old 12-31-2008, 08:58 PM   #9 (permalink)
wedebrook's Avatar
stay away from that. sounds like spring spacers/clamps. bad business.
Rule #2: It's wrong to be French.
wedebrook is offline   Reply With Quote
Old 12-31-2008, 10:24 PM   #10 (permalink)
05ss45's Avatar
im goin too get vogtlands springs with KYB AGX's.. i read alot of good stuff about that setup!
SLP headers, 3.8/3.5 MPS,v1.0 DHP PCM, Grant built trans, intense I/S, Trans-Go shift kit, 2800 stall(Comp Cams custom grind 2 be installed)
05ss45 is offline   Reply With Quote
Old 01-03-2009, 04:16 PM   #11 (permalink)
Thatisugly's Avatar
hey im looking into lowering my impala also, could you link me up to the setup your running, i am a noob to this suspension so i am somewhat daft to what i need.
Also, should a get lowering shocks, like the kyb agx's? or eibach springs with stock shocks?
im looking for about a 2 inch drop maybe more, ride comfortability doesnt matter to me i don't drive the car hard or on a track or anything
Old 01-27-2009, 02:37 PM   #12 (permalink)
01 Blackout's Avatar
Send a message via AIM to 01 Blackout
eibach pro kit drops 1.4 in the front and 1.7 in the rear.. it's a good ride and looks awesome with some bigger aftermarket rims on it
01 Blackout is offline   Reply With Quote
Old 02-17-2009, 11:32 AM   #13 (permalink)
Natedogg713's Avatar
Send a message via AIM to Natedogg713
whats the eibach pro kit? like what does it include?
Natedogg713 is offline   Reply With Quote
Old 02-17-2009, 11:52 AM   #14 (permalink)
wedebrook's Avatar
four lowering springs. the ride is a little harsh, according to some, so i ordered the SSC springs from ZZPerformance.com, but they failed to tell me they were out of stock. so i cancelled my order and just bought the Canuck Motorsports off ebay, which are the exact same thing as the SSC springs, just under a different brand name. same drop height and same part number. was right around $200 shipped.
Old 02-17-2009, 12:09 PM   #15 (permalink)
hows the ride?
Lowering a Wagon nosduh89 Wagon Discussion 13 10-16-2010 05:10 PM
eiback lowering springs new08impy 8th Gen Suspension 5 06-27-2010 10:16 AM
Drop spindles or lowering springs? TITANIC Wagon Discussion 10 09-30-2009 02:02 PM
can anyone know of a shop in va that can install my lowering springs 96impalablck22 Chevy Caprice 3 12-13-2008 03:17 AM
