Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 7th Gen Discussion > 7th Gen Engine Performance
Old 06-23-2008, 09:16 PM   #1 (permalink)
LaFrance454's Avatar
Easiest way to do the U-Bend Delete Kit
I just sold my 02 chevy 2500 for a 00 3.8 impala. Just bought it today and cant stand not having the exhaust like my truck. People say A U-bend delete kit and a cat back is the answer. Cat back is coming but will it sound fine if i dont get rid of the U-Bend or what ever?
LaFrance454 is offline
Sponsored links
Old 06-24-2008, 06:36 AM   #2 (permalink)
Heavy_SS's Avatar
Dont know what you mean by U-bend?
Eric Iverson
96 BBB SS
51 k and counting.
Typical newbie mods, with no gas in the tank.
www.minnessota.com
Heavy_SS is offline
Old 11-12-2008, 08:18 PM   #3 (permalink)
Lingenfelter's Avatar
I don't think you'll see much, if any, tonal change between having the ubend in there and not having it in there. The ubend may free up 2-3 horsepower, which is nothing all that measurable.
Your choice of muffler and resonator (or no resonator) will have a far bigger impact on the sound.
HeavySS: A ubend is a peice in the 00+ Impala exhaust systems where an O2 sensor is plugged in. It follows the catalytic converter and checks the efficiency. It is literally a bend in the pipe that looks like a U. It's a bit restrictive. Removing it means installing an aftermarket downpipe from ZZP or another company, or simply cutting out that section of pipe and replacing it with a straight section.
Removing the Ubend may cause a check engine light due to funny readings from that second 02 sensor. In 2000-2003 models, an O2 simulator can be used so that you don't need to drill a hole in your exhaust and reinstall that sensor... but you may fail emissions if they look under the car and realise you no longer have a second O2 sensor under there.
Top 10 poster at NAIOA.
Top 10 poster at NewImpala.
Lingenfelter is offline
Old 11-12-2008, 08:20 PM   #4 (permalink)
73impala's Avatar
Send a message via AIM to 73impala
id go with flowmaster
73impala is offline
Old 11-13-2008, 06:23 AM   #5 (permalink)
04DetroitLS's Avatar
leave the res in if you go flow IMO, the drone can get annoying
its a little long but was waiting for the idle to kick down ;)
I NEVER threw any codes when i deleted mine, i put the o2 90* clockwise from where stock is, just watch they dont pinch/scrape the wires when they relocate it. You wont hear a difference by removing it either.
BEST way to delete it is to grab a downpipe (ZZP/3800performance/etc), if you grab the long catless one, it'll bolt to exsisting cat back. The down pipe is the most restrictive part of the exh on our cars, then the u bend, 2 birds 1 stone ~$200. then you can figure what you want for catback after wards ;)
I am Wanderson's bitch .
See the NEW project:
http://www.fullthrottlev6.com/forums...ad.php?t=59648
04DetroitLS is offline
Old 11-13-2008, 06:29 AM   #6 (permalink)
73impala's Avatar
that impal sounds reallly nice
73impala is offline
Old 11-13-2008, 07:25 AM   #7 (permalink)
05ss45's Avatar
id go with the down pipe that has a u-bend delete like 04DetroitLS said 2 birds 1 stone, & it is one of the most restrictive parts of the exhaust.
SLP headers, 3.8/3.5 MPS,v1.0 DHP PCM, Grant built trans, intense I/S, Trans-Go shift kit, 2800 stall(Comp Cams custom grind 2 be installed)
05ss45 is offline
Old 11-13-2008, 07:37 AM   #8 (permalink)
ty ;)
Old 12-06-2008, 01:02 PM   #9 (permalink)
pimpstrocity's Avatar
how much would the total increase in hp be with the u-bend deletion and the new down pipe? On a 04' ls with the 3800
pimpstrocity is offline
Old 12-06-2008, 05:59 PM   #10 (permalink)
>5hp, you'll loose bottom end torque but make up top end hp, it really helps the car if there are a few other mods (IE Hviii) OR THE S/C Cars, the dp/u bend are the most restrictive areas of the exhaust. If you buy an aftermarket dp w/ cat. Dont buy the ubend kit if you are going cat back, the exh.shop can do it for you ;)
vB code is On
please delete my account moneypit Site Bugs and Problems 4 10-25-2008 12:05 AM
I have a 2006 Impala LT. What would be the easiest and most efficient way to get swooshmvp Chevy Impala Discussion 1 09-12-2008 05:34 AM
How do you do an air pump delete on an 96' Chevy Impala SS ? Jp J Chevy Impala Discussion 1 05-08-2008 09:22 PM
Bumper Delete Ideas 64RatRod Impala 1st - 5th Gen Discussion 5 03-15-2008 10:25 PM
Sitemap Index - Archive
