Car hesitating when accelerating - Chevy Impala Forums
post #1 of (permalink) Old 08-09-2012, 10:58 AM Thread Starter
biglo's Avatar
Hey guys, I have a 2005 chevy impala 3.4 base and I have a problem where I accelerate my car sort of hesitates, kinda jerking a bit. Like if going but it doesnt want to keep going. It normal happens between30 - 40 mph right on 35mph most of the times. Its really getting to me now I changed all spark plugs leads and I've changed my coils as well. Plus I changed the fuel filter. I wondering if it would be the ICM (ignition control module) or something like that. But any help would be appreciated.
biglo is offline
post #2 of (permalink) Old 08-09-2012, 11:47 AM
I eat brains... gimme brains!
pbNJ's Avatar
I had the same problem a few years ago right after I did a tune up on my 3.4.. I brought into the stealership for a diagnosis and it turned out to be a bad #3 plug wire.. since I just replaced them w/ brand new stock wires, I put my old one back on and that fixed the problem.. I contacted ACDelco about my problem and they sent me another brand new #3 wire... never had the problem again
pbNJ is offline
post #3 of (permalink) Old 08-09-2012, 11:54 AM
Quoted: 15 Post(s)
What RPMs are you at with this? Are you flooring it?
Also....moved to 7th gen engine.
donmateo is offline
post #4 of (permalink) Old 08-10-2012, 07:32 AM
jrd0304's Avatar
Does it only happen when the car is at full temp? What kind of coils did you buy? Delcos or another OEM brand?
I feel your pain. I've been going through a similar situation myself in my 2003 3.4. Jerky, like the trans is acting up, but only at full temp. No check engine light, just an annoying, intermittent, seemingly harmless but still very aggravating jerk/hesitation on slight throttle when cruising. Comes and goes like the wind. Goes away when you give it more gas.
I've been chasing this ghost for a long time, at least a year maybe longer.
Long story short, I've been running two original factory coils on an engine w/188K, and one aftermarket OEM BWD coil. After doing a lot of what you've tried, (new plugs, new wires, new fuel filter, etc), I broke down and got three brand new AC Delco coils, and put them on last night. I am waiting to see if it goes away, it hasn't come back yet after a couple trips, but I'm still not positive the issue went away yet.
I've been reading some other forums, and many other makes/models have had DIS coil issues, but no check engine light since the problem isn't severe enough to exceed misfire counting in the PCM. It's almost like a bad coil won't throw a pending code or anything unless it's 110% fried up.
I will let you know if that helps me, not saying it will fix your issue, but it sounds like we're having similar problems.
jrd0304 is offline
post #5 of (permalink) Old 08-10-2012, 08:30 AM
Quoted: 7 Post(s)
Biglo, I realize you're probably interested specifically in Do-It-Yourself advice, so I just wanted to jump into the thread quickly to let you know I'm available via direct message anytime if you would like me to research further on your behalf!
Best,
Katie
Chevrolet Customer Service
post #6 of (permalink) Old 08-10-2012, 11:06 AM
Joe
Joe's Avatar
Changed the wires?
If you have a CEL or SES light on the dash, have the car scanned to see if is throwing a code.
Not sure how the Impala is setup, but I had a similar problem on my GMC pickup, turns out it was the fuel pump.
Other items I had to do periodically to the truck were cleaning the MAF and throttle body. May apply to the Impala as well.
** SOLD ** 2005 Impala - Base with a bunch of options / Debadged
1967 Camaro RS/SS L78 - Perpetual restoration project
2007 Trailblazer SS - Red Jewel
Joe is offline
post #7 of (permalink) Old 08-10-2012, 03:26 PM
Back in Black
12ltz's Avatar
My wife's 3.4 had a problem like this cleaned MAF and IAC and no more problem.
12ltz is offline
95 SS starts hesitating Impala9596 Chevy Impala 6th Gen Discussion 7 07-09-2012 10:56 AM
Car dances a jig when accelerating tonyc712000 Chevy Impala 7th Gen Discussion 8 05-31-2012 08:31 AM
'96 4.3L Hesitating 1stCaprice Automotive Discussion 2 11-14-2011 03:24 AM
2003 9C1- throwing codes and hesitating HighwayLurker Chevy Impala 7th Gen Discussion 7 03-30-2009 07:37 AM
