3800 n/a swap to 3800 s/c - Chevy Impala Forums
post #1 of (permalink) Old 09-22-2009, 10:23 AM Thread Starter
ImpalaLSS954's Avatar
Send a message via Yahoo to ImpalaLSS954
I have a 2002 Impala LS with a n/a 3800 motor that has 140,000 plus miles on it and im entertaining the idea of putting a s/c 3800 motor from the impala ss in my car, along with the tranny, suspension, etc., etc. My question is, does anyone know where i can get these parts from in reliable condition & for a reasonable price or would it just be cheaper for me to get a hold of a 2004-2005 impala ss and do the swaps that way? Any & all suggestionz are greatly appreciated. Thankz!!
ImpalaLSS954 is offline
post #2 of (permalink) Old 09-22-2009, 10:50 AM
Moderator
04DetroitLS's Avatar
you can do the swap for about $2k, trans will be another 2k+ for a GOOD WELL BUILT reliable tranny that will handle most boltons
theres an ImpSS for 7500 in Holt MI right now... I can get you a list of stuff you need for a topswap later if still interested...
04DetroitLS is offline
post #3 of (permalink) Old 09-22-2009, 11:13 AM
blusail's Avatar
That would be a hell of a trek from MI to Davie. You probably could check around on the local craigslist's down there. I imagine that you could probably find one in the Miami area with as bad as people drive down there.
blusail is offline
post #4 of (permalink) Old 09-22-2009, 01:25 PM
Moderator
wanderson75's Avatar
IIRC you just need:
Gen III Eaton M90 Supercharger
L67 throttle body
lower intake manifold
cylinder heads
fuel rail w/ injectors
valvecovers front and rear
harmonic balancer
idler pullies, brackets, tensioner, etc for supercharger belt system
coil pack
MAP sensor and bracket
And done. Waiting for DLS to confirm.
–adjective
wanderson75 is offline
post #5 of (permalink) Old 09-22-2009, 02:25 PM
Moderator
pretty much sums it up (+ gaskets and fluids)
Stock L36 coils WILL work, they just put out a little less juice, Im still running the L36 coils
also recommended
L67 fuel pump, again you can run the stocker, but every little bit helps, if you dont get the pump, get the rewire kit
LS1M Scanner (or something to scan data w/)
4T65EHD upgrade (avail thru Morad Parts Co or ZZP/Intense)
used parts, check Ebay (please post link to m90 PRIOR TO BUYING) or Morad parts (latter is recommended)
Secondary air pump and check valve on a 3800 - where??? Gator762 Chevy Impala 7th Gen Discussion 1 07-14-2009 07:50 PM
Putting an s/c on a n/a 3800 2004 impala. pimpstrocity 7th Gen Engine Performance 3 01-09-2009 08:56 PM
Do i really need to use dex cool in my 2004 impala ls v6 3800 Chris K Chevy Impala Discussion 2 08-06-2008 08:19 PM
chevy impala 3800 engine? skirfer Mechanical and Electrical Problems 1 04-01-2008 06:36 PM
04 impala 3800 series II deadgame05 Autocare and Maintenance 1 03-02-2008 07:25 PM
