Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 7th Gen Discussion > 7th Gen Engine Performance
Old 09-13-2008, 06:31 AM   #1 (permalink)
02impala's Avatar
Question Throttle body spacer?
I was wondering do throttle body spacer give you any horsepower gains our are they a waste of money? Thanks for any input
02impala is offline
Sponsored links
Old 09-13-2008, 07:15 AM   #2 (permalink)
04DetroitLS's Avatar
IMO waste of $, unless you are going to use it to spray the car.
Try to find a HVIII, real gains of about 20hp. some good starting mods would be:
-FWI/CAI
-HVIII
-L26 UIM & LIM w/ "green gaskets"
-powerlog
-Downpipe
-180* t-stat
if you want to go further than that grab some 1.9 Roller Rockers or a cam
dont forget a pcm tune too!
I am Wanderson's bitch .
See the NEW project:
http://www.fullthrottlev6.com/forums...ad.php?t=59648
04DetroitLS is offline
Old 09-13-2008, 07:53 AM   #3 (permalink)
02impala's Avatar
if u mind me asking whats a HVIII?
02impala is offline
Old 09-13-2008, 08:09 AM   #4 (permalink)
High Velocity Intake Insert
HVII -orig, HVIII - Improved
The High Velocity Upper Intake Manifold Insert replaces the factory plastic runners in the upper intake manifold found in FWD Series II 3800's. Simply remove the upper intake (leaving the throttle body attached), pull out the stock runners, set the HV insert in the intake and bolt it back down
More torque - The HP gains of the old HV2 were quite amazing. The only issue was a loss in low end power. This meant that only highly modified setups could take full advantage of the high rpm gains. The new HV3 has slighty longer runners to give more HP and torque in all usable rpms!
Easier install - The new HV3 doesn't require special length bolts, RTV or any modifying of your factory setup. It sits entirely inside of the factory upper intake. It can be installed in less than 30 minutes.
More reliable - The HV3 does not require RTV, cannot be seen by anyone looking at your external engine, and it comes with a new intake gasket. Installing the new HV3 actually improves the reliablity of your car by replacing a potentially worn out gasket. Because it sits entirely inside the intake, there are zero sealing issues.
does not work w/ the L26 UIM/LIM, so it's an either/or issue
Old 11-10-2008, 08:30 PM   #5 (permalink)
muskyhunter5675's Avatar
i drive an 01 base model impala with the 3800 can i put that hvIII thing on my car? and where do you get it?
2001 Impala 3.8
muskyhunter5675 is offline
Old 11-10-2008, 08:58 PM   #6 (permalink)
yes, its only for the 3800 (L36)
http://www.zzperformance.com/grand_p...=214&catid=113
Old 01-05-2009, 05:24 AM   #7 (permalink)
pimpstrocity's Avatar
Originally Posted by 04DetroitLS View Post
How does that effect your mpg? Besides for a s/c im trying to keep the upgrades on my car having positive or neutral effect on my mileage.
pimpstrocity is offline
Old 01-05-2009, 12:22 PM   #8 (permalink)
05ss45's Avatar
so are you planning on installing a blower, if so you would not be able 2 run an HV3.
SLP headers, 3.8/3.5 MPS,v1.0 DHP PCM, Grant built trans, intense I/S, Trans-Go shift kit, 2800 stall(Comp Cams custom grind 2 be installed)
05ss45 is offline
Old 01-05-2009, 02:55 PM   #9 (permalink)
Gonna try, trying to find a good plan to get in on since mine is the n/a 3800.
http://www.grandprixforums.net/f17/t...lots-7763.html
My friends swears that the same top swap or style of top swap would work on my car, that and there is a thing on zzperformance about the conversion. Any input on whats easiest and best?
vB code is On
coolant bypass throttle body crapice95 Mechanical and Electrical Problems 0 12-06-2008 03:30 PM
Is it true I can throw the 454 throttle body onto my TBI350 to wake that mother up? Bigb9000 Off-Topic Discussion 13 11-05-2008 11:45 PM
Throttle Body Spacer impala04ss Chevy Impala Discussion 4 10-16-2008 05:35 AM
Throttle body+Air foil seth7796 Chevy Impala Discussion 1 04-15-2008 02:37 PM
i have a 1992 chevy caprice and it needs a engine a 5.7 throttle body 350 right? Jeff G J Chevy Caprice 2 02-20-2008 09:42 AM
Sitemap Index - Archive
