Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 7th Gen Discussion > 7th Gen Drivetrain
Old 05-07-2008, 01:41 PM   #1 (permalink)
L36_IMPALA's Avatar
2000 LS (Transmission code)?
I registered to ask a transmission question for my fathers Impala.
We need to know what the transmission code is.
It needs to be replaced.
Upon searching I found the code : 4T65-E
But the mechanic tells me that he needs a LNB or LNN number of some sort.
I am guessing that this has to do with the gear ratio's.
Could you guide me toward my answer?
Thanks in Advance.
L36_IMPALA is offline
Sponsored links
Old 05-07-2008, 05:23 PM   #2 (permalink)
Moose's Avatar
If memory serves me rightly, there is a tag riveted to the front of the transmission, i believe it's white (about 2" by 3", and the letters are around 3/4 of an inch high). The code should be on there.
Failing that, the code should be on the SPID (Service Parts Identification) Label. Usually on the underside of the trunk lid.
And if it's not there, try calling the GM dealer with the VIN, they should be able to shed a little more light on it for you.
Hope this was of some help.
The code is basically to tell the dealer/tech working on the vehicle what final drive ratio the transmission has.
Take a picture of the label, and post it here, if you need any more help. I wish I could run the VIN and help ya out, but I work at a Ford store, sorry.
I assume that you're putting a used trans in this car? It's a lot of work to swap these transmissions, you might want to consider having it rebuilt, as opposed to putting a used unit in. I have not had a great deal of luck with used 4t65-e's.
94 BBB Clone
94 9C1 LT1
93 GMC K3500 4x4 6.5TD
88 Chevrolet Suburban 6.2 3/4 Ton
Ford Diesel Certified Technician
Moose is offline
Sponsored links
vB code is On
error code p0440 2001 impala? steve c Chevy Impala Discussion 1 03-02-2008 10:24 AM
Code P0171 on 2000 impala? cmoven Chevy Impala Discussion 0 02-27-2008 10:25 AM
2000 Chevy 1500 manual transmission pops out of first gear? Zorlinda General Automotive Discussion 1 09-10-2007 11:43 AM
1996 buick park ave p0102 code? shalagre General Automotive Discussion 1 09-09-2007 07:20 AM
eXTReMe Tracker
Sitemap Index - Archive
