Transmission Service - Chevy Impala Forums
post #1 of (permalink) Old 09-19-2012, 03:20 AM Thread Starter
charmer37's Avatar
Smile Transmission Service
Hello Everyone,
I have a 03 Impala Ls with a 3.8L V6 engine and i would like to know do anyone have any step by step instructions on how to change the automatic transmission filter and also how many quarts of transmission fluid do i need to refill the transmission....Thanks
P.S. would adding a transmission additive along with my transmission fluid help or harm my transmission
charmer37 is offline
post #2 of (permalink) Old 09-19-2012, 10:13 AM
Sure, simple. Raise and support the front end, get the biggest drain pan you can find, you'll need a funnel, medium sized flathead screwdriver, hammer, and a ratchet with an extension and 10mm socket. Take out the pan bolts, be careful because fluid will start pouring out before you get them all. Save the gasket and reuse it if it is the metal core and rubber gasket, if it's fiber throw it out and get it all off the sealing surfaces. Pull the filter, it's only pressed in. Use the hammer and screwdriver to carefully get the filter seal out, hurt the seal all you want, just don't hurt the case. Carefully drive the new seal in till it seats, lube it with fluid, and install the new filter, then reinstall the pan. Tighten bolts every other bolt all the way around till you get all of them, get them good and snug, but not too tight as they will break off. Use the funnel and add fluid through the dipstick hole, should be about 7 quarts, pour in 6, then with the car level, start the engine and shift slowly through all the gears with your foot on the brake. Engine still running, car in park, get out and check the fluid level, add as needed. Done.
post #3 of (permalink) Old 09-19-2012, 10:37 AM
463
463's Avatar
Hi:
Remove the 20 oil pan bolts Remove the oil pan and catch the fluid in a catch panRemove the oil pan gasket . Use a screwdriver in order to pry the oil filter assembly out of the case. Do not damage the case sealing surface. Use a small screwdriver in order to pry the oil filter seal assembly out of the case. Do not damage the case sealing surface. Inspect the oil pan for the following conditions:
A damaged sealing surface
A dented or cracked bottom surface
Inspect the oil pan gasket for the following conditions:
A bent or damaged seal core
A damaged rubber seal surface
A damaged gasket
Inspect the oil pan magnet for damage or misalignment Clean the oil pan , the oil pan gasket and the oil pan magnet in order to remove any sediment. Inspect the oil pan magnet for steel particles. Excessive amounts of steel shavings indicate internal transmission damage. Lubricate the oil filter seal assembly with transmission fluid. Using a socket of the same size as the seal and a plastic mallet, gently tap the oil filter seal assembly into the case. Install the oil filter assembly into the case . Install the oil pan gasket onto the case . The old gasket is reusable if the gasket is not damaged. Install the oil pan onto the case . Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
install the 20 oil pan bolts.
Tighten the bolts to 14 Nm (10 lb ft).
Always use DEXRON-III labeled automatic transaxle fluid.
Using a long-neck funnel in the dip stick fill tube add 7.8 quarts then after adding fluid, recheck the fluid level re check the level useing the proper procedure and check for leaks.
Welcome to the forum
463 is offline
post #4 of (permalink) Old 09-19-2012, 10:45 AM
463
463's Avatar
I think i might have to type just a bit faster, there kingnutin all good points here.
463 is offline
post #5 of (permalink) Old 09-19-2012, 02:55 PM
One note to change on yours, do NOT use dexron III, use dexron VI.
post #6 of (permalink) Old 09-19-2012, 05:44 PM
463
463's Avatar
I feel that on a rebuild dexron VI would be the plan. On a pan drop i would stick dexron III back in to keep the all dexron III. I know that GM says its ok to add IV in to III but not to add III into dexron IV system.
On the transmission additive question i would stay away from additives.
I did put Z max trans in a 700r4 with 120000 miles and it was still working at 220000 miles so was it a good idea or not?
463 is offline
post #7 of (permalink) Old 09-19-2012, 07:28 PM Thread Starter
charmer37's Avatar
Smile re:Transmission Service
Thanks guy's, I appreciate everyone's time and patience
post #8 of (permalink) Old 09-20-2012, 04:34 PM
The old spec was dex III, but was updated to dex VI even including the 7th gens, since its full synthetic it handles heat much better and the trans will last much longer. As for mixing, it won't do any harm. They say not to add III to VI, but you can add VI to III, thats only because they don't want you adding the old type at all.
post #9 of (permalink) Old 06-18-2014, 01:36 PM
Jerome's Avatar
Hi my transmission is pouring from on top what does that mean
Jerome is offline
Service Air Bag VelvitJones Chevy Impala 8th Gen Discussion 34 03-21-2017 03:53 PM
100k service ljbrandt Autocare and Maintenance 1 07-03-2010 11:08 AM
Chevy Dealer Transmission service Alathea Chevy Impala 7th Gen Discussion 2 02-19-2010 08:22 PM
Service tips? roundthirteen Chevy Impala 7th Gen Discussion 9 01-17-2010 11:17 PM
9C1's still in service COLD STEEL Off-Topic Discussion 21 04-01-2009 01:32 PM
