2000 impala 3.8L 3:05 ratio trans LBB OR LPB?? - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 7th Gen Discussion > 7th Gen Drivetrain
Old 08-13-2012, 06:53 PM   #1 (permalink)
coolman3030's Avatar
how do i figure out if car is supposed to have LBB or LPB trans, car currently does not have a transmission in it and i am not able to locate the trans that came out of it so the trans ID plate is not an option, and dealership was not helpful
i did figure out its an f83 code car and has the 3:05 ratio trans, car was MFG 3/2000 according to door sticker,
i do have the vin:
2G1WH55K4Y9313928
THANKS IN ADVANCE,
Dustin
coolman3030 is offline   Reply With Quote
Old 08-13-2012, 06:55 PM   #2 (permalink)
also, is there a way these can be interchanged? if so how expensive is it for the pCM reflash, ect...
Old 08-14-2012, 07:33 AM   #3 (permalink)
00impala123's Avatar
Should be able to look it up by the VIN, but I'm not sure where online you can use.
Also, you can interchange them. The PCM flash isn't too expensive. If you find someone local they may do it for $50. If not you can get an OTS tune from one of the vendors for around 100 bucks. They can put in the new ratio, and you'll get some other goodies as well
00impala123 is offline   Reply With Quote
Old 08-14-2012, 04:51 PM   #4 (permalink)
i really would rather not go the pcm reflash i was hoping to just swap in the correct trans, any other ideas?
LinkBack to this Thread: http://www.impalaforums.com/7th-gen-drivetrain/329249-2000-impala-3-8l-3-05-ratio-trans-lbb-or-lpb.html
2000 impala 3.8L 3:05 ratio trans LBB OR LPB?? - Chevy Impala Forums This thread Refback 08-13-2012 09:05 PM
94 caprice trans problem/questions (trans rebuild) dustin3207 Chevy Caprice 5 04-18-2011 07:41 PM
2000 LS trans shift solenoids I THINK bushy409 7th Gen Drivetrain 3 07-15-2010 06:49 AM
what gear ratio to do 3.73 or 4.10? Fearthedeerss Chevy Impala 6th Gen Discussion 2 02-16-2010 06:51 PM
Changing Trans Fluid On 2000 Impala Ls 2000ImpalaLs 7th Gen Drivetrain 4 03-02-2009 02:39 PM
will a 2000 trans am run on regular or mid-grade? icnmayhem Automotive Discussion 1 09-09-2007 01:00 PM
