2002 Impala, 3.4L engine mount, how to? - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 7th Gen Discussion > 7th Gen Drivetrain
Old 06-09-2012, 11:54 AM   #1 (permalink)
Hi,
My son's 2002 Impy needs an engine mount (ie, passenger side mount to frame, 3.4L). The factory manual says to remove the entire car and motor from the frame, then swap the mounts and put it back together.
Okay, I exaggerated a bit. But before I start building/renting "special engine support fixtures" and removing the "three-way catalytic converter pipe from the right rear exhaust manifold", I thought I'd ask here how others have done this.
Any chance I can just put a jack under the oil pan (with some lumber in the sandwich) and lift the motor up a bit without using a special support or removing the cat pipe? I'm okay with removing the engine strut mounts - that's easy enough - but getting a special fixture or removing exhaust stuff amounts to more that I'm up for.
Any advice or links to how-to write-ups is appreciated.
plano-doug is offline   Reply With Quote
Old 07-23-2012, 06:43 AM   #2 (permalink)
BigCee's Avatar
From what I've read, I believe you can do it the way you said, with a jack and wood on the oil pan with the car up on jack stands.
BigCee is offline   Reply With Quote
Old 08-12-2012, 07:39 PM   #3 (permalink)
BigCee's Avatar
Did you go with hydraulic mounts or solid ones? Can anyone recommend some good aftermarket mounts for the 3.4L?
Poly Motor Mount & Poly Dogbone Mount 06ChevySS Private Wanted Classifieds 2 04-30-2012 08:19 AM
7th gen engine mount / alt bracket 04DetroitLS Private For Sale Classifieds 1 02-15-2011 06:11 AM
2002 impala engine issues jamesbondlq Automotive Discussion 13 03-27-2010 10:06 PM
2002 Impala - Engine Issue? abc Mechanical and Electrical Problems 3 09-20-2007 09:15 PM
2002 Chevy Impala Engine Problem? jjg004 Mechanical and Electrical Problems 1 09-05-2007 09:00 AM
