Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 7th Gen Discussion > 7th Gen Drivetrain
Old 01-14-2009, 12:09 PM   #1 (permalink)
indyimpalass's Avatar
Question Service Traction Control System
I just had this message posted yesterday for the 1st time. I have 28,800 miles and have not changed the brakes yet (does not need new pads yet). The owners manual is not helpful...just says to take in for service when warning light goes off.
It's currently below -0 and has been for a couple of days. Snow every day for 3 days and the traction control system is getting used quite frequently. I do drive the car hard, so I'm thinking about changing tranny fluid and filter.
Any recommendations or ideas?
Thanks!
IndyImpalaSS
indyimpalass is offline
Sponsored links
Old 01-14-2009, 02:31 PM   #2 (permalink)
capricewiz's Avatar
is the ABS light on? I would take it to your local shop and find out what the codes are in the abs system
capricewiz is offline
Old 01-14-2009, 04:45 PM   #3 (permalink)
ABS light is on
Yep, the ABS light is on and that function is not currently working as well. I'm being told it could possibly be froze up sensors?
IndyImpalaSS
Old 01-15-2009, 05:57 AM   #4 (permalink)
04DetroitLS's Avatar
most likely its a bad connection at the sensor, its a fairly typical issue
I am Wanderson's bitch .
See the NEW project:
http://www.fullthrottlev6.com/forums...ad.php?t=59648
04DetroitLS is offline
Old 01-15-2009, 02:43 PM   #5 (permalink)
capricewiz's Avatar
sorry, I need to codes to help you better. They have wiring issues, not just connection problems.
Old 01-15-2009, 04:34 PM   #6 (permalink)
thats what i kinda meant, the wires tend to fray near the connection @ the hub
Old 01-15-2009, 05:26 PM   #7 (permalink)
capricewiz's Avatar
they also have a tendency to unwind in the conduit and then rub against the side of the oil pan causing an intermittent problem. Sometimes if you spray salt water on the harness it'll act up if its not already. That's why they replace the wiring harness all the way up to the harness split.
Old 02-15-2009, 05:33 AM   #8 (permalink)
**Update**
It's the rear right wheel sensor...it's resistance is all over the place, so the hub needs to be replaced. GM is going to honor my warranty claim for this part, so I got that going for me. I believe the code was C1235, which is a difficult to decipher according to one of my tech buddies.
IndyImpalaSS
Old 02-15-2009, 06:03 AM   #9 (permalink)
cool gald to hear that GM is picking up the tab as well ;)
Old 02-15-2009, 07:09 AM   #10 (permalink)
Yep...they also need to pickup the tab on the tranny cooler lines, which are leaking too!
IndyImpalaSS
vB code is On
loving the traction control Jam545 Chevy Impala 7th Gen Discussion 7 02-09-2010 08:53 AM
Service Traction Control problem AKvsAR Chevy Impala 7th Gen Discussion 23 07-04-2009 03:29 PM
Service Traction System **Update** indyimpalass Autocare and Maintenance 2 01-23-2009 05:26 PM
Traction control service light cfjames11 Autocare and Maintenance 3 12-07-2008 12:38 PM
2002 Chevy Impala Service Traction System Light comes on with ABS light;... preciousmoments Mechanical and Electrical Problems 2 09-06-2007 02:01 AM
Sitemap Index - Archive
